FOAK: Full of sound and fury ... except for the sound bit.
Discussion in 'UK Motorcycles' started by AndrewR, Jul 20, 2006.
  1. AndrewR
    AndrewR Guest
    For some reason when I play videos from any web-page I don't get any sound
    with them, but if I save them and run them in stand alone applications
    they're fine.
    The problem occurs in both Opera and IE, so it's not browser specific.
    I've updated all of the software I can think of updating (i.e media player,
    flash, Real, etc.)
    It's not limited to one site.
    All of the stupid options have been checked for - I don't have mute on, my
    volume is turned up, my sound card is working, there isn't a power-cut at
    the moment, etc.
    Any bright ideas?
    BTW, I was particularly keen to hear the product demo video from this site
    .... http://www.saber-edv.com/home/ ... because I fancied a laugh.
    AndrewR, D.Bot (Celeritas)
    Kawasaki ZX-6R J1, Fiat Coupe 20v Turbo
    The speccy Geordie twat.
  2. Do you still get system sounds?
    Si
    Mungo \Two Sheds\ Toadfoot, Jul 20, 2006
  3. AndrewR
    AndrewR Guest
    No, now that you mention it and if I go to the system sound set up bit it
    won't let me play sounds.
    That doesn't sound good ... no pun intended.
  4. Join the club.
    XP home + SP2?
    Go and try every single "cure" for this known problem (without success), get
    the updates from MS which say they are for precisely this problem, reinstall
    every driver which is even remotely associated with sound, spend hours
    trying to find even more updated drivers, remove every piece of kit from
    your pc which is associated with a/v, buy a new sound card, sit scratching
    your head, do it all again. Give up.
    **** all works.
    I haven't tried a format and reinstall because I can't be arsed but I
    believe that will be the only cure.
    I suppose it's possible that the sound card I bought (eBay special) in case
    the onboard sound had just gone tits up might not be compatible with SP2 but
    I haven't bothered getting a more recent card yet.
    Best of British to you, Sir
    si
  5. AndrewR
    BGN Guest
    IF it's only started recently then he could probably try a rollback if
    he has it enabled.
    BGN, Jul 20, 2006
  6. AndrewR
    zymurgy Guest
    I think i've spotted your problem.
    Cheers,
    Paul. (Win 2000 - Yay !)
    zymurgy, Jul 20, 2006
  7. AndrewR
    catman Guest
    IME you're fucked. Live with it or re-install.
    Had exactly that issue, tried everything on line. Nothing made a blind
    bit of difference.
    It's a know issue, with know understood cause.
    www.cuore-sportivo.co.uk
    catman, Jul 20, 2006
