FOAK: Duc 900SS, ie version
Discussion in 'UK Motorcycles' started by YTC#1, Jun 19, 2008.
  1. YTC#1
    YTC#1 Guest
    If anyone has one, or a manual, can they check the front wheel is a Brembo
    3.50 x 17 please ?
    YTC#1, Jun 19, 2008
  2. YTC#1
    YTC#1 Guest
    YTC#1, Jun 19, 2008
  3. YTC#1
    antonye Guest
    Yes it is. Common across all of the Ducati bikes, with the
    only difference being the front axle size.
    Easiest way to tell is the older carby (smaller 20mm axle) wheels
    go from fat spokes at the hub and stay fat at the edge, eg:
    http://horrible.demon.co.uk/600ss/050311_dd_09.jpg
    The later (ie version) go from fat spokes to thin spokes and
    use the same 25mm axle bearings as the 916 and 999 line:
    http://i27.photobucket.com/albums/c165/dkspares/may 2/Picture014-5.jpg
    They're all twin disk too; a plastic cap using 3 bolts of the
    bolt holes covers the disk mount. They're all made by Brembo.
    Note that a carby 900SS wheel won't fit a 900SSie and vice
    versa, but a 748/916/996/998 wheel will fit a 900SSie. Also
    Monster and SS wheels and disks are identical.
    That enough info?
    antonye, Jun 19, 2008
  4. YTC#1
    YTC#1 Guest
    Hmm, can't access that one
    Ah.
    That would be the one I had my eye on.
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=220244783335
    They could not say what year it was from, so you are saying that won't fit
    the 750ss ..... bugger
    And just dragged the wheel in to compare, so I can see what you mean.
    That saved me some dosh, ta.
    looks like I am back to ringing alloy repair places.
    Yes thankyou.
    Got any spare wheels :-(
    YTC#1, Jun 19, 2008
  5. Out of interest, what aftermarket wheels are available, and what are the
    ones to choose? And prices?
    The Older Gentleman, Jun 20, 2008
  6. YTC#1
    antonye Guest
    To be honest, nobody really bothers changing their wheels from what
    I've seen. You get a few people that want the forged versions or
    that will buy a set of Marchesini mags, or maybe even stump up 1500
    for a trick set of carbon wheels, but it's very rare.
    The standard ones are good enough and you can pick them up cheap
    enough
    to not really worry about it. People tend to paint them or polish up
    the rims instead.
    antonye, Jun 20, 2008
  7. YTC#1
    antonye Guest
    Try refreshing it. It's sitting on my box at home so should
    be available if you keep trying.
    No, that won't fit yours (even though it's the same *wheel* size) as
    the axle bearing sizes are different. You *can* convert them by
    removing
    the bearings, replacing the inner spacer (that sits between the
    bearings)
    and then fitting new bearings in the right size. You could rob the
    spacer
    out of your duff wheel or you can still buy them from Ducati
    (#71420041A)
    and then either use pattern bearings or Ducati parts (#751612054) but
    pattern parts will be about 1/5th of the price.
    We did the same thing but went the other way - using an old wheel (cos
    that's all we had) on a larger axle. The bearings cost about £13 for
    the pair as they were the same as some FIAT rear axle or something!
    If all that hassle doesn't sound worth it, keep an eye out for a cheap
    Monster or SS wheel (they are the same) but remember that it might
    turn
    up and have fucked bearings anyway...
    When I checked it would be about £50 to have one repaired. As you can
    buy them off ebay for about that, it didn't seem worth it once you'd
    factored in the repaint.
    Between myself and Mark we have about a dozen wheels, so we may well
    have one that will fit straight off; I'll check and let you know.
  8. YTC#1
    YTC#1 Guest
    I don't think they are cheap
    YTC#1, Jun 20, 2008
  9. YTC#1
    antonye Guest
    I paid less than £50 each for both front and rear off ebay.
    How cheap do you want them?!?!
  10. YTC#1
    antonye Guest
    It's probably because they used the same wheel across the whole
    range of bikes so there are plenty of them about. Ducati are
    great at either reusing parts between models and not messing
    with stuff on model revisions either. Pre-1098, Ducati calipers
    came in two flavours - 40mm mounting or 65mm mounting - and
    they were all made by Brembo. As long as you knew which size
    mounts you had you could buy one of anything and it would fit.
    Up until the 999, all Ducati brake disks were identical fitments
    too - all Brembo, all 320mm - and you could even use Guzzi and
    Aprilia ones 'cos they were the same.
    The radial calipers on my Hypermotard are the same monoblocs
    that are used on the 1098S and 1098R.
  11. YTC#1
    antonye Guest
    They aren't any good for Bruce as they are the SSie ones anyway.
    The (working) links are here, previous years on the left:
    http://www.ducati.com/en/bikes/service/manuals/2008.jhtml?family=manuals
    There is a copy of both the workshop manual and the parts
    manual on the GMail drive for it though.
  12. YTC#1
    YTC#1 Guest
    Well, 1st we have to find some ....
    I;ve no patience, its summer, it needs riding
    YTC#1, Jun 20, 2008
  13. YTC#1
    YTC#1 Guest
    Thats 'cos I was concerned over the answer being none ie
    YTC#1, Jun 20, 2008
  14. YTC#1
    antonye Guest
    I know what he meant, and he didn't want to know about the SSie
    models ;-)
  15. YTC#1
    antonye Guest
    I think...
    He originally wanted to know what size the front wheel from
    a 900SSie was, in case it was the same size as the one on
    his 750SS (carby). It is the same size wheel but not the
    same size bearings, hence the protracted thread on Ducati
    wheels...
    **** knows, I didn't understand that either!
    antonye, Jun 21, 2008
  16. YTC#1
    YTC#1 Guest
    I was in a rush, I was concerned that the ie version may not fit, which
    turned out to be the case
    Oh, and YHM on the address in your header
    YTC#1, Jun 21, 2008
  17. YTC#1
    YTC#1 Guest
    Posting after beer
    YTC#1, Jun 21, 2008
  18. YTC#1
    antonye Guest
    ukrm.net is bjorked.
    I'll email you instead.
  19. YTC#1
    Eddie Guest
    Doesn't make the bits cheap when you buy them new though, does it?
    I got a new brake light switch for the Elefant today: £23.90 for a
    microswitch, two bits of wire, two pairs of tiny nuts and bolts and a
    little nylon bush. Robbery!
    Eddie, Jun 21, 2008
  20. YTC#1
    antonye Guest
    Aren't they the same as Kawasaki; about £1.49 a time? ;->
