FOAK : Drilling Copper
Discussion in 'UK Motorcycles' started by Brownz @ Work, Aug 16, 2006.
  1. Hi All,
    Googling has proven far from fruitful, so I'm back to ask the experts.....
    1 x Solid Copper Lump (Computer Heatsink Core).
    4 x 1mm - HSS/Cobalt PFX A907 Jobber Drills
    - Use on alloy steel, titanium alloy and nickel
    1 x Pillar Drill.
    How would one progress through the lump of copper ?
    Slow / Fast ? Coolant / Dry ? I've just snapped one drill off already, so
    don't want to lose another !
    Piccy of aforementioned copper here :
    http://atschool.eduweb.co.uk/brownie/hs_job.jpg
  2. Brownz @ Work
    Cane Guest
    Take the helmet off.
    Cane, Aug 16, 2006
  3. Brownz @ Work
    veeeal Guest
    google for zero rake drill
    veeeal, Aug 16, 2006
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, "Brownz @ Work"
    Use milk as a coolant. Yes, seriously, it works very well on copper.
    My gut feel would be to go as fast as your pillar drill can manage for
    such a small drill, and "peck" it. Remove the drill from the hole
    frequently to allow it to cool and clear the swarf.
    Hold the job in a drill vice, preferably bolted to the drill table. You
    really don't want it to move during the drilling.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer As featured in
    Performance Bikes
    Wicked Uncle Nigel, Aug 16, 2006
  5. Not in the time frame I have, plus I'm not going to attempt to grind down
    the correct angles on a 1mm bit !
    Ta anyway. Noted for future ref.
  6. I have some thin coolant, so I'll give that a go.
    I'd set it to the slowest speed, so that was probably my problem.
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, "Brownz @ Work"
    I'll bet milk works better, it makes an amazing difference IME.
    Keep the feed rate low. I meant to ask, are these through holes, or
    blind holes? If they're through then take very great care when the drill
    breaks through.
    It'll still snap, but at least you took care... ;^)
    Performance Bikes
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    I've got a couple of spares. Remind me next time we're due to meet up
    and I'll bung one in the bag.
    Performance Bikes
  9. Brownz @ Work
    <Pats new Record drill press vice>
    Hog, Aug 16, 2006
  10. Is that your only vice ?
  11. Brownz @ Work
    <pats new Record bench vice>
    Hog, Aug 16, 2006
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    In copper?
    Performance Bikes
  13. Job done, no snap-age either, which is a bonus.
    A patient process of drill a few mil, clear the swarf with a comp air can,
    add a little lube, repeat til end.
    http://atschool.eduweb.co.uk/brownie/job_done.jpg
    Couldn't find any milk so had to make do with two of those little tubs of
    "Millach Maid" coffee whitener, which seemed to work a treat - it realy is a
    great milk substitute ;-)
    Thermocouple fitted and setting as we speak, train ticket booked to Lahndarn
    tomorrow. Job's a good un' as they say.
    Eye thang ewe for your expert advice sir, you are a true gent.
  14. Nip down your local Lidl - a couple of weeks ago they were selling just
    that thing and you might find one or two left.
    Grimly Curmudgeon, Aug 16, 2006
  15. Surprised me too. It wasn't a heavy-duty thing, but ok for a quid.
    Grimly Curmudgeon, Aug 17, 2006
