FOAK: Connecting my laptop to internet via an N70
Discussion in 'UK Motorcycles' started by Cane, Aug 25, 2006.
  1. Cane
    Cane Guest
    I've seen someone do this using the cable that comes with the phone.
    How do I set it up?
    TIA
    Cane, Aug 25, 2006
  2. Cane
    catman Guest
    At a guess: Run CD that comes with phone. Connect cable
    dial.
    www.cuore-sportivo.co.uk
    catman, Aug 25, 2006
  3. Cane
    Ben Guest
    There're comprehensive instructions in the pdf manual that comes on
    the disc with the phone.
    Bluetooth is the more elegant way of doing it though.
    Ben, Aug 25, 2006
  4. Cane
    Steve Parry Guest
    If your laptop has bluetooth you don't need the cable as the N70 is
    bluetooth enabled, I use my fones (3230 or 6670) to connect via GPRS and
    bluetooth to the web. If you're laptop has'nt got bluetooth, get a newer one
    and stop being pikey ;) ... if it hasnt tho' you could use a cable.
    You'll need to ensure your phone provider has enabled GPRS on your account
    and you'll need to get the required settings from them.
    Vodafone do a good "connectme" software. O2's is pretty pants and fails to
    recognise most of their newer phones. But the workaround is to enter the
    details manually. Orange and the others I guess all do their own software
    but the easiest is to contact your phones support people and ask for help in
    setting it up if you've not done it before.
    Once set up it works a treat. So far I've only used GPRS and it works OK,
    about the same speed as an old dial up modem at home. I've not used the
    newer 3G systems, I understand they offer broadband speed via the phone.
    Steve Parry, Aug 25, 2006
  5. I've used Bluetooth to enable my mobile to use a traditional dial up
    connection, and it worked fine - no GPRS needed in that event. 3G is great -
    high speed, as you say. But can be expensive, especially if it drops back to
    GPRS.
    Ali
    Alison Hopkins, Aug 25, 2006
  6. Cane
    Steve Parry Guest
    true 'nuff .. only problem with normal mobile dial up is it's only 9600bps
    which is less that 25% of the speed of a landline modem. I found this to be
    tediously slow.
    On a personal note, not bothered about the costs, the 6670 is a company
    connection and they pick the tab :)
  7. Yup, you and me both.
    Get them to buy you a 3G card. :)
    Ali
  8. Cane
    Cab Guest
    Or buy a bluetooth dongle.
    Cab, Aug 25, 2006
  9. Cane
    Cane Guest
    I've got one of those so I can talk to the phone via Nokia PC Suite.
    Cane, Aug 25, 2006
  10. Cane
    Steve Parry Guest
    in which case you can use it to create a dial up account as mentioned ^^ up
    there
  11. Cane
    Pete Fisher Guest
    I use a cable connection from my creaky old VAIO to my trusty old T68i
    (been through an automatic washing machine) for Vodafone GPRS . A
    Onespeed subscription helps to enhance speed and keep the data
    transmission down (and hence costs), but only works if you use an XP
    'Dial up' connection rather than Vodafone 'connectme'.
    | Pete Fisher at Home: |
    | Voxan Roadster Moto Guzzi Mille GT/Squire RS3 Gilera Nordwest |
    Pete Fisher, Aug 25, 2006
