FOAK:Checkpoint VPN
Discussion in 'UK Motorcycles' started by Antonio, Aug 9, 2006.
  1. Antonio
    Antonio Guest
    Are there any budding experts on Checkpoint VPN's?
    I have been using R60 NGX and found it doesn't tend to like Boingo Free WiFi
    software very much.
    It will connect the WiFi over non-VPN as long as you like, but once VPN is
    active, it will only keep the connection (WiFi) up for a while, and then for
    some reason force disconnects it.
    I believe the Diagnostic might reveal more info why, but not totally sure if
    messages in there were relevant. There were plenty of messages that on
    recollection mentions local IP address vs "Office mode" causing an
    encryption failure.
    I am just wondering if the VPN has enough of encryption errors of a
    particular type (due to WiFi and VPN combo), and perhaps then decides the
    active security policy must kill the connection (thinking its like a dial
    up, which it ain't).
    Of course the VPN connection cannot even name a WiFi connection to bind to
    the particular connection (or this one can't, lets be clear), so the VPN is
    running over the usual "LAN". So its not like a specific named connection is
    set in the software, by me at least.
    I traced the settings causing the problem (and fixed it) by removing enabled
    settings for NAT-T, Connectivity enhancements and Hub Routing mode - which
    found to be in force I tried on an earlier R56 "clean install" and found it
    to not reproduce the problem. I mirrored the settings in R60 (which was
    deployed with an existing policy however hence the new settings) and found
    it then worked.
    The question is, no one can tell me what those settings do and we don't have
    a direct Checkpoint support contract. We have a european centre that does
    but I may struggle to get them to answer the problem. I also doubt the
    company would fund NGX certification.
    I have the solution, I am just not totally sure what the problem is. Or
    something.
  2. Antonio
    Mike Buckley Guest
    Uh, I've just done the NGX cert, but we're not using it yet. I did the
    accelerated course, which didn't even cover the VPN enhancements, cock
    up by Checkpoint - nothing new there then.
    This needs fixing, are you using office mode?
    Unfortunately for you, Checkpoint have really messed with the VPNs in
    R60, adding such features as virtual tunnel interfaces, route based VPNs
    and other gubbins. There's *masses* of stuff in the manuals about this,
    but I'd suggest googling - phoneboy is a good start, as is cpug.org. If
    you set VPN_DEBUG to 1 you can check ike.elg and vpnd.elg for errors,
    there's also srinfo if you're using SecureClient (but you may need to
    download it).
    All our VPNs (on R55) are site to site, so I don't have much direct
    experience with remote access stuff.
    Mike Buckley, Aug 10, 2006
  3. Antonio
    Mike Buckley Guest
    I'm not at work, so ukrm doesn't have my undivided attention at the
    moment.
  4. Antonio
    Antonio Guest
    Thanks Mike
    I checked and R56 however is no different. It seems if you JUST tick the hub
    mode, it screws that particular software causing those disconnects (but no
    other WiFi software, strangely). Turn off that Hub mode, and its fine.
    I have been advised that Hub mode is "necessary" for infrastructure security
    which is a bit of a pain, we can stick with this workaround without telling
    them and risk it or check out other s/w. No answers as to what it is or how
    to troubleshoot it though.
    Shame, as Boingo (besides being US specific) is quite a good (free) product.
    I tried Mcafee wireless security which when I tried it before did not work.
    It seems to be ok now though. The interface is a little shite. Free though
    (their WPA product anyway, they do a managed secure product at cost).
    Also PCTEL Sugue, which was quite interesting, works (although misidentified
    a point as WEP when it was in fact WPA, but manually configures fine). A set
    of completely unnecessary skins for it too which are quite mental. Not free,
    $19.95.
    So I think I have it under control, but no clue really to solving the
    problem. Its a bit of a pain when I have already created my own userguide to
    using WiFi that centres around Boingo, which otherwise is an ideal, most
    user-friendly WiFi product I have seen (it just allows connect/disconnect
    and leaves the technical bullshit graphs and monitors out the equation -
    ideal for a userbase).
    The main reason for selecting a hardware independant model is because of a
    mixed platform of hardware/software base by the way, otherwise internal
    stuff would be the way to go.
    Antonio, Aug 10, 2006
  5. Antonio
    anybody43 Guest
    This is complete speculation:-
    I don't know if this will help or not but as I understand it Hub Mode
    forces all traffic to go over the VPN to the central firewall. Once
    there
    it is subjected to the rules applied there and forwarded if
    appropriate.
    So for example once the VPN is up ordinary web browsing
    goes via the central site.
    Perhaps Boingo uses some communications that is being
    blocked by the central site? Even if it is not being blocked
    the central site will be NATting it to its address which may
    confuse Boingo. Or maybe Boingo cannot accept that traffic
    coming in from its internet side when they expect to see it
    coming from the direction of your PC?
    I would guess that a load of corporates will use similar VPN
    confgurations and Boingo should fix it if they want that
    market.
    When you have hub mode off, traffic not heading for the LAN
    at the central site just goes directly off over the internet.
    I would start there anyway.
    You could always run a packet sniffer on the laptop and
    see what traffic it is sending and if it is getting
    the expected responses.
    Luckily;-) SecureClient comes with one.
    [Ctrl]C to stop it.
    If you press no buttons (i.e. create no network traffic) then
    just maybe you will get to see something intresting such
    as your PC trying to check-in with Boingo and getting no response.
    Thing is that without a lot of network knowledge interpreting
    such a dump is pretty tough.
    if you did
    srfw monitor > some-file.txt
    [Ctrl]C to stop it.
    you could look at it at your leisure.
    Post it on the web and I could have a look.
    Stop the trace as soon as the Boingo connection drops.
    If you can't tell when it drops do a ping in another window to
    say www.google.com and stop the trace as soon the ping fails.
    The critical thing is to create no extraneous network traffic
    /at all/ so that the packets that we are interested in are
    as obvious as possible and to stop the trace as soon as
    the connection fails such that the problem should be at the
    end of the trace. Kill off anything that is creating
    network traffic that you do not need.
    Finally, you could do a similar exercise with the VPN
    down,or not in hub mode, and compare the results.
    Good luck.
    anybody43, Aug 11, 2006
  6. Antonio
    Antonio Guest
    Cheers. Its possible but I have found a lesser desirable solution by testing
    out another alternative, platform independant solution.
    In this case, the McAfee Wireless Security (with WPA) does a reasonable job
    (although I have had some inconsistency with a T41, particularly on
    manipulating the power setting for wifi - even if I close their application
    down). Worked very well on Toshiba Tecra S-2 though. It doesn't "detect"
    when the Radio is down like Boingo, though.
    I need to further this and make sure its up to the job.
    I could try what you suggested but I might need to check through the log to
    make sure I am not giving away any security related information that could
    compromise our network.
    I wonder whether this would help actually lead to a solution as well, but
    anyway can't hurt to examine.
    PS I think the utility you refer to MIGHT be the SecureClient "Diagnosis"
    tool /Logs (seen when in Connect mode), which I have already used. But I
    might be wrong....
    Another client I tried was the PCTel client but it was a bit naff, US
    specific and even more unreliable with the VPN client, but great WMPlayer
    style "Skins" lol.
    Odyssey works very well and we could get this internally but the
    infrastructure for it has not been laid out yet, and no guarantee for when
    it will.
    The Boingo client is free and great for our needs generally speaking and
    also designed BY a HotSpot vendor, which is somewhat the point.
    I think the stuff designed by IT guys/ hardware manufacturers has gone off
    at a tangent and lost the plot, in terms of simplicity of use.
    For instance Toshiba Config-Free, if poorly used alongside their Auto-switch
    mode can leave a load of network adapters in a "disabled" state !
    Fortunately, XP provides the Zero-Config which is pretty basic and useful,
    but what about 2000 clients ?
    But being outside of the US, we aren't even allowed to be subscribers of
    Boingo anyway (cross-competitivity with TheCloud you see) and I wonder
    whether we would get much support.
    I did bang a question in to them but naff all back so far.....which probably
    explains their point of view.
    Antonio, Aug 13, 2006
