FOAK: Chain Help
Discussion in 'UK Motorcycles' started by David Thompson, Jul 14, 2004.
  1. I've had a B6 from new last October, and have covered just under 9,000
    miles, but I can no longer [1] adjust the chain to keep it
    appropriately tensioned.
    Regardless of whether I adjust the chain as per manual recommendations
    (using the swing arm marks), measuring rule or straight edge, the
    tension of the chain varies when I rotate the back wheel. It looks as
    though the chain does not sit uniformly on the sprockets throughout
    it's entire length, instead sitting someway up the teeth around the
    bottom of the sprocket causing the tension to become too tight.
    All the teeth of the sprocket look good, there is no 'hooking' and all
    the chain links move freely.
    You also hear a slight brushing sound, the frequency of which varies
    with speed, when the bike is in motion.
    As best as I can tell the wheel is in alignment.
    Is this a case of the chain becoming unevenly stretched?
    I lubed the chain regularly [2], but summise that this is probably not
    sufficient. If I have to shell out for a new chain, would a Scottoiler
    help prolong it's life? What is a reasonable life of a chain anyway?
    If it's of any consequence, most trips are between 50 and 80 miles;
    not a lot of short runs.
    [1] Perhaps proof that I never could!
    [2] Minimum of monthly, but more in the wet.
  2. Yes.
    Replace.
    William Grainger, Jul 14, 2004
  3. David Thompson
    <SNIP>
    It's fucked. Time to replace it.
    Ace, Jul 14, 2004
  4. David Thompson
    If it's the standard one, it's shite. I've got a DID Xring on my one
    now, which is a good chain.
    Muck, Jul 14, 2004
  5. David Thompson
    Ace wrote in
    and if you plan to keep the bike for some time then a Scottoiler will pay
    for itself. I fitted one to a TDM850 and the bike still had the original
    chain on it at 16,000 miles when I sold it.
    wessie, Jul 14, 2004
  6. I've fitted a scottoiler to every bike i've owned and am in the process of
    fitting one to my ZX10R (1). Can't recommend them enough really especially
    if you ride through winter.
    (1) if I can find a space big enough to take the resevoir which is currently
    proving difficult.
    Grimley_Feindish, Jul 14, 2004
  7. David Thompson
    Grimley_Feindish wrote in
    Can you fit the number plate kit? Holds the larger touring reservoir.
  8. It's a good idea as a last resort and one I hadn't thought of, thanks.
    That's another £32.00 though and the number plate arrangement is already a
    bit ugly imo. One place I'd thought of was on the rear hugger next to the
    chain guard. Will require drilling a couple of small holes to take the cable
    ties but it'll be out of the way and easy to route the pipe work. Hope the
    weather holds off for Saturday :)
  9. David Thompson
    PDannyD Guest
    <snip>
    Chain's fuckereded. Replace.
    Fit a chain oiler. Scottoilers are simple and effective.
    Buy a quality chain.
    Occasionally turn up the oil flow on the chain oiler to give the chain a
    really good oil-wash.
    In 9000 miles of both-wheels-on-the-ground riding in all weather I've only
    had to adjust the Fazer's chain twice. Each time, it took no more than
    half a turn on the adjusters to do it.
    PDannyD, Jul 14, 2004
  10. David Thompson
    Rope wrote in
    you seem to be typing with a cold
  11. David Thompson
    I've only had one bike that I fitted a Scotoiler to and that was a GS550
    (which are heavy on chains). I really rated it. From adjusting the
    chain every 500 miles to adjusting it every "many miles".
    There wasn't any appreciable fling; certainly no more than regular
    aerosol lubing caused.
    sweller, Jul 14, 2004
  12. Chains! Tsssssk!! Waste of time and money :)
    Dave OSOS#24 Remove my gerbil for email replies
    Yamaha XJ900S & Wessex sidecar, the sexy one
    Yamaha XJ900F & Watsonian Monaco, the comfortable one
    http://dswindell.members.beeb.net
    Dave Swindell, Jul 14, 2004
  13. David Thompson
    K Olley Guest
    Yep
    Kevin - Basildon
    XV535
    GPZ305 (her's)
    BOTAFOT#67 BOTAFOF#23
    OSOS#29
    K Olley, Jul 14, 2004
  14. David Thompson
    I've never bothered. Modern materials are great, and mean that chains,
    unless _severely_ neglected, don't need adjusting at all between
    services.
    I imagine they'd have done so at the gixxer's first service/rear tyre
    change at ~6000km, although there was no noticeable slack at that
    point, so they may not heve needed to. I certainly never have.
    Ace, Jul 15, 2004
