FOAK: Car advice needed
Discussion in 'UK Motorcycles' started by Champ, Nov 5, 2008.
  1. Champ
    SteveH Guest
    That's the old shape.
    SteveH, Nov 6, 2008
    #61
  2. Champ
    Ace, Nov 6, 2008
    #62
  3. Champ
    Nahay?
    _______
    Ace, Nov 6, 2008
    #63
  4. Champ
    Adrian Guest
    Probably because they're a size bigger - the Passat's pitched against the
    A4.
    Adrian, Nov 6, 2008
    #64
  5. Champ
    No it ain't - the Passat is a full size up from the A4. It's actually
    got more interior space, leg(and elbow)-room wise, than the A6 Avant.
    One might argue that it places more alongside the new A5, but I don't
    think (without having tested one) that's quite as big, so possibly
    not.
    _______
    Ace, Nov 6, 2008
    #65
  6. Champ
    SteveH Guest
    'Proper quattro' is a mechanical system with a torque sensing diff.
    Transverse engined cars (ie. Golf based stuff) use a hydraulic system.
    The main difference in road use is that the Haldex reverts to something
    like 90% FWD most of the time, whereas quattro delivers 60% to the rear
    in normal use.
    SteveH, Nov 6, 2008
    #66
  7. Champ
    SteveH Guest
    New A4 is significantly bigger than the old one - pretty much the same
    size as the current Passat.
    I don't think it really places it alongside the A5, though, 'cos the A5
    is a coupe - although you could argue the Passat CC sits in the same
    class as the A5.
    SteveH, Nov 6, 2008
    #67
  8. Champ
    Cane Guest
    Just you wait until someone posts about their cat..
    Cane, Nov 6, 2008
    #68
  9. Champ
    Simon Wilson Guest
    Nowt wrong with a bit of danger, cage-boy.
    If you don't want the P6000's - I can make good use of 'em on mine?
    btw did it lock up both sides? I had an issue with a sticking caliper
    resulting in one front locking up far too easily.
    Simon Wilson, Nov 6, 2008
    #69
  10. Champ
    Eddie Guest
    Eddie, Nov 6, 2008
    #70
  11. Champ
    Cane Guest
    O Rly?
    Cane, Nov 6, 2008
    #71
  12. Champ
    Ben Guest
    I nearly ran my cat over last night.
    Ben, Nov 6, 2008
    #72
  13. Champ
    Not tested one, as they came out after I'd ordered the passat.
    <googles>
    Yes, they seem to be much more similar in size, just a bit shorter, a
    bit narrower inside, a bit less cargo space. But definitely in the
    same ballpark now.
    Heh.
    _______
    Ace, Nov 6, 2008
    #73
  14. Champ
    k, I gets'z it nowz.
    _______
    Ace, Nov 6, 2008
    #74
  15. Champ
    Ben Guest
    rly, bai
    Ben, Nov 6, 2008
    #75
  16. Champ
    Cane Guest
    kthxbai
    Cane, Nov 6, 2008
    #76
  17. Champ
    stop trying to pretend you know what's going on.
    darsy, Nov 6, 2008
    #77
  18. Champ
    Cane Guest
    oh and you do, do you?
    Cane, Nov 6, 2008
    #78
  19. Champ
    prawn Guest
    darsy 0xffwns the Internet. Hell, he practically invented it.
    prawn, Nov 6, 2008
    #79
  20. Champ
    prawn Guest
    I blame Bear.
    prawn, Nov 6, 2008
    #80
