FOAK: Broadband set-up question
Discussion in 'UK Motorcycles' started by SaladDodger, Feb 29, 2008.
  1. SaladDodger
    SaladDodger Guest
    Only while I'm still at work. :-(
  2. SaladDodger
    Colin Irvine Guest
    <g> So ring me - you should find my number if you know where to look.
    Colin Irvine, Feb 29, 2008
  3. SaladDodger
    SD Guest
    All sorted now. :)
    SD, Feb 29, 2008
  4. SaladDodger
    Colin Irvine Guest
    Super!
  5. SaladDodger
    SD Guest
    I was wondering why the performance was pretty much the same as
    before. :)
    SD, Feb 29, 2008
  6. SaladDodger
    Colin Irvine Guest
    <g> Welcome to the world of solid connections and good customer
    service.
  7. SaladDodger
    heh. It didn't make much sense to me, and I work with computers for a
    living.
    Champ
    ZX10R | GPz750turbo | GSX-R 600 racer
    My advice as your attorney is to buy a motorcycle
    To email me, neal at my domain should work.
    Champ, Mar 1, 2008
  8. SaladDodger
    You'd never know.
    Lozzo, Mar 1, 2008
  9. SaladDodger
    Not sure it that's an insult or a compliment...
    Champ
    Champ, Mar 1, 2008
  10. You may well be correct..
    Phil
    Phil Launchbury, Mar 3, 2008
  11. 'Computers' != 'networks'..
    VC = 'virtual circuit' - used in conjunction with VPI (Virtual Path
    Identifier) to define the circuit. In the UK VC usually is set to 38
    and the VPI to 0.
    Which is again fairly meaningless unless you know anything about ATM
    (or packet-switched networks which also use virtual circuits).
    Phil.
  12. SaladDodger
    ginge Guest
    Phil, did you ever consider that as a project manager Champ doesn't
    really want to know any of this?
    ginge, Mar 3, 2008
  13. SaladDodger
    I'd struggle to think of anyone who 'works with computers' (i.e. in
    the IT industry) who doesn't also have to deal with circuits.
    And back to my original point, that it wasn't much use for SD trying
    to get his router to work.
    Champ
    Champ, Mar 3, 2008
  14. SaladDodger
    I've worked 'with computers' in IT since 1984 and I've never needed to
    deal with, or know anything at all about, circuits.
    CT, Mar 3, 2008
  15. SaladDodger
    Weird. I have no idea why I typed 'circuits' there. I meant
    networks.
    Spose I'd better live life to the full before alzheimers takes
    complete hold.
    Champ
    Champ, Mar 3, 2008
  16. SaladDodger
    I thought you might not have written what you meant!
    But it still holds - I don't have to, and never have had to, 'deal'
    with networks. That's someone else's job. And, even if I knew what to
    do, more and more I find that I won't have admin rights in order to do
    it anyway.
    I recommend riding a motorbike. Fast.
    CT, Mar 3, 2008
  17. SaladDodger
    oh come on. Never pinged a server? Never wrestled with a connection
    string for a database? Never created a web service over http?
    Roger and Wilco
    Champ
    Champ, Mar 3, 2008
  18. SaladDodger
    I suppose he could be a Windows Mobile developer.
    I had a (for me, slightly surreal) conversation with such a chap a
    little while back - someone who I've known for years, and has worked
    in various IT jobs for a similar length of time to me. Turns out - and
    I know you'll find this hard to believe - he'd never used an RDBMS,
    and didn't really know what they were for.
    Apparently, in the Windows Mobile world, all data is just held in flat
    text files, and you write your own indexing in the application.
    darsy, Mar 3, 2008
  19. SaladDodger
    Yes, but if it fails, I am usually unable to do anything about it.
    Yes, but if it doesn't connect, I am usually unable to do anything
    about it.
    No.
    Maybe we're having issues over what you mean by 'deal'. Pinging a
    server is not 'dealing' with a network; troubleshooting & resolving
    problems is. IMO, of course.
    CT, Mar 3, 2008
  20. SaladDodger
    What I meant by 'dealing' was essentially 'using', and knowing when
    you have a problem. And knowing enough about the problem to get
    someone to fix it.
    Champ
    Champ, Mar 3, 2008
