Cold weather, knackered central heating system. First radiator in chain was only warm at bottom, so spent an hour getting air out (if its too cold to go to the garage to get a flat headed screwdriver a chisel will do) result lovely warm radiator. Radiator in hall completely cold, radiator key actually fits this one result warmish radiator. Checked temperature setting on boiler, turned up from minimum. Other radiator in main hall also cold at top, radiator key didn't fit, socket set used. Result, burny hot water with black hot spludge squirt over floor and people. Towel mopping ensued. When it squirted flicked controls to off. Stopped squirting by putting the bleed valve back in. Turned controls back on. Boiler warmed up water. Pump whirring round radiators no get hot. Help required. Why isn't it working? Anyone in area at weekend feel free to poke it, bring your own towels and burn kit.
