FOAK Big singles
Discussion in 'UK Motorcycles' started by Grimley_Feindish, Sep 21, 2005.
  1. I had the Duke services about 400 miles ago and it was running much smoother
    and ticking over properly instead of sounding like it had a stutter (the
    bloke I bought it off hadn't bothered to sort this out when he put the cans
    on it and rejetted the carb) although it did cut out when going to pull away
    at lights on a few occasions. I put this down to it not being properly
    warmed up as it only seemed to do it within a few miles of starting out.
    Last weekend I fitted the KTM "Y" piece for the exhaust and rejetted the
    carb to the recommended 180 plus the other bits they say to do. It fired up
    OK and has been running fine, noticeably better pull from about 3000rpm.
    However, it seems to be cutting out more often now. It'll tick over for ever
    and runs fine when moving, just suddenly dies when you go to pull away or
    slow down to a walking pace slipping the clutch at a junction or in traffic.
    Not all the time but enough to be pain and it always starts up again on the
    button.
    I thought maybe it could be the float level set too low (high?) on the carb
    but thought I'd ask here before I go poking about.
  2. Grimley_Feindish
    Veggie Dave Guest
    There are at least two electrical connectors to check - the first one is
    the one between the stator and coils. The second one is where the side
    stand cut-out switch wires plug onto the loom
    The former resulted in me shearing my arm in half...
    Veggie Dave
    UKRMHRC#2 BOTAFOF#08
    IQ 18 FILMS http://www.iq18films.com
    Extreme Racing http://www.veggie-dave.co.uk
    Toxic Shock Syndrome Gets More Girls Than Me
    Veggie Dave, Sep 21, 2005
  3. Cool, I'll give them a look, it's possible they might have vibrated loose,
    everything on me has so far :). How did you shear your arm in half checking
    an electrical connection, just out of curiosity like.
  4. Grimley_Feindish
    Veggie Dave Guest
    I was stood on the seat doing a wheelie when the electrical fault
    appeared
    Veggie Dave
  5. Grimley_Feindish
    Steve Parry Guest
    <fx: Charlie Boorman opens black book> ;)
    Steve Parry
    K100RS SE & F650
    (not forgetting the SK90PY)
    http://www.gwynfryn.co.uk
    Steve Parry, Sep 22, 2005
