FOAK: Battery reviver additives
Discussion in 'Classic Motorbikes' started by Buzby, Jun 5, 2006.
  1. Buzby
    Buzby Guest
    I'm know this has been done to death, but can I find it? No.
    I've a relatively new but tired battery that won't take a charge due to
    infrequent use of the SVOC and suspect it's clogged up - there was a
    chemical that can be added to 'unclog' - I'd be very grateful for the info
    as a new one is well over a hundred quid . . . . .
    Buzby
    Buzby, Jun 5, 2006
  2. Buzby
    The pills Halfords sell have been recommended in the past, if that's
    any help.
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    Krusty, Jun 5, 2006
  3. EDTA. To do it properly, you need to drain the battery, wash out the
    crap from the cells and refill it with electrolyte before adding EDTA.
    Follow up with a long slow regulated charge - about 0.5 amp for a week.
    If you want a quick and dirty fix...
    You can revive a partly sulphated one with some EDTA (bout 1/2 tsp per
    cell) and try it.
    Grimly Curmudgeon, Jun 5, 2006
  4. Buzby
    Buzby Guest
    Cheers - That's the one I was after.
    Buzby, Jun 5, 2006
  5. Buzby
    Buzby Guest
    Ta - I'll check it out - see they contain any of that there EDTA which
    comes highly recommended
    Buzby, Jun 5, 2006
  6. In uk.rec.motorcycles, Buzby belched forth and ejected the following:
    Batt-Aid is the stuff you want.
    Whinging Courier, Jun 5, 2006
  7. Just be aware that most batteries have come with EDTA added already
    for quite a few years. I think the best procedure would probably be to
    put as much charge into the battery as possible (to get the plates in a good
    oxidation state) then drain, rinse with distilled, fill with new electrolyte
    and the recommended amount of EDTA, then put on trickle charge for a while.
    Dr Ivan D. Reid, Jun 5, 2006
  8. Buzby
    Me here Guest
    Nah
    That's what Englands cricket team uses
    Me here, Jun 6, 2006
  9. Buzby
    Buzby Guest
    Duly noted - many thanks
    Buzby, Jun 6, 2006
