FOAK: Bar end weight problem - HELP?
Discussion in 'UK Motorcycles' started by Fr Jack, Dec 11, 2005.
  1. Fr Jack
    Fr Jack Guest
    Can anyone help me sort this problem?
    My RHS bar weight came loose, the other day. I tried tightening the screw,
    *gently*, but it just kept rotating, rather than pulling in and nipping
    up.
    I gently pulled on the weight and it slid out into my hand. Arse!
    If you look at the link, below and scroll to the bottom right corner,
    you'll see an exploded view of the arrangement:
    http://www.ronayers.com/fiche/300_0285/handlebar/handlebar.cfm?man=su&groupid=4800&parent=4740
    I've looked down the bar and there's a rubber left inside (6) and, the nut
    (obviously).
    I've taken the screw (3) and tried to get it to catch the thread, but no
    go. I've tried to extract the rubber, using the screw and sideways
    pressure, while pulling, but no go.
    Anyone any (serious) ideas how to sort this?
    Cheers!
    Fr Jack
    B12S (The Red Mist), CB450DX (The Moped)
    FRJACKUKRM AT GMAIL DOT COM
    Red death, to set you free
  2. Fr Jack
    muddy Guest
    Wire coat hanger wiv a tiny hook bent in the end of it?
    muddy, Dec 11, 2005
  3. Fr Jack
    muddy Guest
    Sorry, but just leave the stuff in there and buy new bits to replace
    them.
    muddy, Dec 11, 2005
  4. Fr Jack
    Fr Jack said...
    You need a nice Snap-On Mini bottom hose hook to get the rubber out.
    I've got one here. The rubber will have part bonded to the inside of the
    bar, you need to break the seal and hook it out. Run a small electrical
    screwdriver round the outside of the rubber and then try to remove it.
    once it's out reassemble the whole bar end as one bit, insert up the bar
    and screw the thing tight.
    Lozzo, Dec 11, 2005
  5. Fr Jack
    Fr Jack Guest
    Hmm.... not sure if there's enough room, with the bend being so close.....
    Cheers!
    Fr Jack
  6. Fr Jack
    Fr Jack Guest
    Considered that, but it's a rather narrow 'ole in the middle of the rubber
    - not entirely sure there's enough room to allow a big enough hook to pass
    through.
    <wanders off to check again>
    Hmm....
    <wonders where to find suitable wire, having no wire coathangers>
    Wonder if Ma will notice if I nick one of hers....?
    Cheers!
    Fr Jack
  7. Fr Jack
    Gareth Guest
    What you need sir is a thick ish welding rod with all the flux chipped off
    and bent 90 degrees at one end, small a bit as possible. Then fettle back to
    a small little hook and go fishing . I had exactly the same problem on my
    b12 and overcame it using above method. If memory serves me right i then
    glued the nut to the rubber for future shenanigans. If my digital camera
    hadn't packed up when i was about to photograph my daughter in her school
    concert i would of sent you a pic of my hook !
    Gareth, Dec 13, 2005
  8. Fr Jack
    I think most people around here would much rather see the pics of your
    daughter[1]
    BTW we post at the bottom round here, & snip sigs, & snip irrelevant
    text etc etc.
    [1] Assuming she's over 16 [2]
    [2] 'ish'
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    '02 MV Senna '96 Tiger '79 Fantic 250
    Krusty, Dec 13, 2005
  9. In uk.rec.motorcycles, Fr Jack amazed us all with this pearl of wisdom:
    Get a long(er) bolt with the same size thread as the one that came out
    and screw it in, then, whip it out with some manly pliers.
    Whinging Courier, Dec 13, 2005
  10. Fr Jack
    Fr Jack Guest
    Sorted it, this evening.
    Made a hook and tried to yank it. No joy.
    Got a bar and gave it a gentle push, then tried the hook, again. Bingo!
    The nut had become detached, so I just hoiked the bike over on its side
    and rapped the bar a couple of times. Job done.
    Not put it back, yet... lack of light.....
    Cheers!
    Fr Jack
    Fr Jack, Dec 13, 2005
  11. Fr Jack
    Fr Jack Guest
    Going to do the same with the nut.... and the washer on t'other side of
    the rubber.
    Re: your posting - please take krusty's advice - that's how we do it, here
    and will save you potential need for an asbestos suit. ;-)
    Cheers!
    Fr Jack
  12. Fr Jack
    Fr Jack Guest
    There wuz nowt to screw into - the nut had made a bid for freedom.....
    Cheers!
    Fr Jack
  13. Fr Jack
    Fr Jack said...
    There's no need to. If you assemble it correctly and don't remove the
    bolt completely when you take the bung off next time, it won't fall
    apart.
    Lozzo, Dec 13, 2005
  14. Fr Jack
    Fr Jack Guest
    I didn't take it apart, I noticed it had worked loose, while on the
    trailer. Tried tightening and ended up with bits in me hand.
    Still - all sorted, now, ta.
    Cheers!
    Fr Jack
