FOAK: Autorun commands and stuff
Discussion in 'UK Motorcycles' started by Cane, May 23, 2006.
  1. Cane
    Cane Guest
    I have two MPEG films that I send out to customers on two CDs. One
    shows laser cutting and the other laser engraving. They autorun when
    placed in the CD drive.
    I'd prefer to send out one CD with both films and a menu allowing the
    customer to chose which movie to watch.
    a] how do I do this?
    b] can someone do it for me?
    c] yes I'll pay if you invoice me.
    Cane, May 23, 2006
  2. Cane
    antonye Guest
    Would be very nice if you made a couple of web pages, like a mini
    web site, that popped up when you put the CD in the drive.
    There would be a nice looking intro page, with some links down to
    more info about the company, contact details and so on. Then you'd
    have the links to the two movies on the disk.
    You should be able to get the page to autorun just by pointing the
    batch at the html page instead of the film. Just make sure all your
    links are suitably named and you'll be fine.
    I'll post you an invoice for the consultancy.
    antonye, May 23, 2006
  3. Cane
    for a start, what format are the movies in - i.e. are you making an
    assumption that your customers will have a particular piece of
    software on their PCs?
    To get started, the CD should have a file called autorun.inf in the
    root directory - you use this to specify what will happen when the CD
    is inserted (or when the user double-clicks the CD's icon in Windows
    Explorer).
    The contents of this file should look like:
    [AutoRun]
    open=whatever.exe
    icon=whatever.ico
    where whatever.exe is the name of the program you want to launch on
    autorun - if you're going to build a webpage with links to your movies
    as Ant suggested, this would read iexplore.exe. The icon line isn't
    necessary - you only need it if you want a custom icon for the
    appearance of the inserted CD in WinExp.
    You'll also need your html file - call it index.html for convention's
    sake. So, the 2nd line of your autorun.inf file should read:
    open=iexplore.exe index.html
    if you want to run IE in kiosk mode, put a space and then -k after the
    html.
    darsy, May 23, 2006
  4. Cane
    I doubt Cane's customers fall into the same sad geek category as you,
    though.
    I very much doubt that'll work.
    darsy, May 23, 2006
  5. Cane
    antonye Guest
    Don't bother with launching IE, just put the filename there instead
    and windows will launch it using the default browser:
    open=index.html
    Saves a load of hassle for the nerds without IE, etc.
  6. Cane
    Vass Guest
    Ulead have a trial download DVD maker with Menu Options
    Vass, May 23, 2006
  7. Cane
    simonk Guest
    What is it with those people? They're already using "windoze", so if they
    think "M$" is evil or buggy, they're kind of pre-fucked
    simonk, May 23, 2006
  8. Cane
    simonk Guest
    If you made a DVD, people could put it in a DVD player or a PC (unless their
    PC's total shit)
  9. Cane
    Cane Guest
    Brilliant. I'll try what you and Ant have suggested.
    Cane, May 23, 2006
  10. Cane
    Has it occurred to you that people use other web browsers because they
    prefer the functionality they offer, rather than just because the hate
    all thing MS?
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, May 23, 2006
  11. Cane
    does that work then?
    I'm sure it didn't use to.
    But then, it's been a very long time since I was involved in CD-ROM
    production.
    darsy, May 23, 2006
  12. Cane
    simonk Guest
    I'm struggling to find a compelling piece of functionality that Firefox has
    and IE doesn't, TBH - you type stuff in, websites appear, etc...
  13. Cane
    try Ant's open=index.html first, because it'll work cross-browser, if
    it works, IYSWIM.
    darsy, May 23, 2006
  14. Cane
    if you want to go the DVD route, I have a full copy of ULead
    MovieFactory (albeit not the latest version).
    darsy, May 23, 2006
  15. Cane
    actually, that's a much better suggestion - it's probably actually
    easier to do for a more professional result.
    Depends on what format his existing videos are in, mind - if they're
    Flash or something...
    darsy, May 23, 2006
  16. Cane
    Vass Guest
    I'd very much like copy please
    Vass, May 23, 2006
  17. Cane
    simonk Guest
    Most of the packages I've used for making DVDs - even iDVD - are pretty good
    at converting between formats, but yes, Flash would take the piss rather.
    Paradoxically, that's probably the best format for a CD/HTML mashup,
    though - Flash is probably available on more computers (PCs and Macs) than
    any single video codec, and in the rare instances when it isn't, it's a
    doddle to download and install.
  18. Cane
    I use Firefox at work, because I use a super-secret proxy that isn't
    monitored by our mailmarshalls / molested bit fucking Finjan
    Surfingate (even the name makes me gag). I use IE for the internal
    apps that I can't access when using the super secret proxy
    darsy, May 23, 2006
  19. Cane
    Did somebody specify firefox? TBH I'd prefer to continue using
    Netscape, except it's been removed from our work machines, for one
    simple reason - if you Cut from an HTML table and Paste it into e.g.
    Excel it's possible for it to dump the entire contents into a single
    column, which makes for much simpler data manipulation. Sure, there
    are other more 'clever' ways of doing this, but with IE you don't get
    this choice.
    _______
    Ace, May 23, 2006
  20. Cane
    it's a pity for you that I don't tend to get involved in pirating
    software, then, isn't it ;-)
    darsy, May 23, 2006
