FOAK: AutoCAD Question - JB, Big Dave?
Discussion in 'UK Motorcycles' started by Cane, Aug 15, 2008.
  1. Cane
    Cane Guest
    If I've got a DXF of an image, in this case a snow flake, is there a
    way by which I can measure the amount of cutting lines in the image?
    Basically I need to know how many metres of cutting there will be for
    each shape.
    TIA
    Cane, Aug 15, 2008
  2. Cane
    Big Dave Guest
    Probably the easiest way is to convert it to a Polyline (if it isn't
    one already).
    Select the polyline.
    Right click
    Go to properties and there will be a Length listed there - probably in
    mms :)
    Big Dave, Aug 15, 2008
  3. Cane
    Simon Wilson Guest
    I'm *cough* years[1] out of date with AutoCad but IIRC if the entity
    were a polyline it would be quite straightforward. There seem to be
    tools to allow you to export the length properties to Excel (eg
    http://www.exefind.com/innersoft-cad-for-autocad-2006-P27077.html),
    though I'd be suprised if AutoCad couldn't do this itself.
    Doesn't your tool part programmer quickly tell you the profile length -
    but then I guess you'd have the program done by then.....
    [1] probably decades ffs
    Simon Wilson, Aug 15, 2008
  4. Cane
    Simon Wilson Guest
    Balls, gingered. Not so out of date then.
  5. Cane
    Cane Guest
    Interesting little app.
    Well perzactly
    Cane, Aug 15, 2008
  6. Cane
    Cane Guest
    Ok, I've got the image open as a dwg. How do I convert it to a
    polyline?
    Cane, Aug 15, 2008
  7. Cane
    Big Dave Guest
    Type <pedit>
    then select any line in the shape
    then answer <y> to the prompt (Object is not a polyline do you want to
    turn it into one)
    then enter <j> at the option prompt (Join)
    then at the [select objects] prompt select the whole shape with a
    window or crossing box (make a mental note of how many items you've
    selected)
    hit return and note how many segments have been added to the polyline
    - it should be 1 less than the number you selected.
    Job done.
    Any problems, e-mail the dxf file to me and I'll sort it out for you :
    dave[dot]benjafield[at]corusgroup[dot]com
    dave[dot]benjafield[at][corusgroup[dot]com
  8. Cane
    Cane Guest
    At this point it says [Object selected is not a polyline] but doesn't
    ask it I want to convert it.
    This is AutoCAD 2007 if that makes a difference
    [ps] taken to email
    Cane, Aug 15, 2008
  9. Cane
    Simon Wilson Guest
    Spoilsport. How are we all going to learn now? The world is on the edge
    of their seats.
  10. Cane
    Cane Guest
    I'll put it in my blog;-)
    Cane, Aug 15, 2008
  11. Cane
    Simon Wilson Guest
    Next to the cock pictures? "How do I calculate the girth of this in
    AutoCad?"
  12. Cane
    Cane Guest
    Measure the circumference of your wife's mouth, that should give a
    rough guide ;-)
    Cane, Aug 15, 2008
  13. Cane
    Big Dave Guest
    In other words, my cock is a mouth round by a throat long?
  14. Cane
    Cane Guest
    <impressive>
    Cane, Aug 15, 2008
  15. Cane
    Big Dave Guest
    <proud>
  16. Cane
    JB Guest
    Zap me the file over if you want and I'll do it tonight.
    JB
    JB, Aug 15, 2008
