FOAK: Anyone used a nortel Business Policy 2000 switch?...
Discussion in 'UK Motorcycles' started by Spike, Feb 3, 2005.
  1. Spike
    Spike Guest
    Im trying to get the console port up on the serial connection, and am having
    **** all luck.. Im missing something obvious...
    Any pointers?...
    Spike, Feb 3, 2005
  2. Spike
    Dr Zoidberg Guest
    What speed and settings are you using on your com port?
    Alex
    www.drzoidberg.co.uk
    www.sffh.co.uk
    www.ebayfaq.co.uk
    Dr Zoidberg, Feb 4, 2005
  3. Spike
    Spike Guest
    9600, 8, none, 1, xon\xoff though Ive also tried the other flow control
    options... :-(
    Spike, Feb 4, 2005
  4. Spike
    Dr Zoidberg Guest
    I take it you are getting nothing at all rather than gibberish?
    We might have some in out stores so I'll have a nose next week assuming I
    remember
    Alex
    www.sffh.co.uk
    www.ebayfaq.co.uk
  5. Spike
    Spike Guest
    Yep, absolutely nowt...
    If you could have a look, and if youve got any of the orignal documentation,
    that would be cool... The nortel site is, well, how shall I put this?...
    Shit.
    Spike, Feb 4, 2005
  6. Spike
    Ged that takes me back. Hardware flow control, whack the speed right up and
    what sort of UART chip have you in your serial card?
    You're not using Rockwell RPI, by any chance?
    platypus, Feb 4, 2005
  7. Spike
    Spike Guest
    Dont think so... Im using the onboard Serial port on my Dell Precision
    340... though Ive also tried my Vaio laptop as well... fucking things! Id
    assume that the switch is fucked, apart from the fact that Ive got two of
    them, they both work, (as switches) and neither of them can I communicate
    with via the comm port.....GGRRRRRRRRRRR!!!!!!!!!!
    Spike, Feb 5, 2005
  8. Spike
    Dr Zoidberg Guest
    No switches in our stores , but this was lifted out of one of the manuals.
    The console port is a DB-9 male connector used to connect a management PC
    to the workgroup switch by means of a straight-through DB-9 to DB-9 standard
    serial port cable. Using a terminal, you can monitor the results of startup
    self-diagnostics, perform manual boot configuration and SNMP agent
    configuration, and customize your network using the supplied menus and
    screens. The console port provides VT100 terminal emulation, running at 9600
    baud and using 8 data bits, 1 stop bit, and no parity as the communications
    format, with flow control disabled.
    In less complex applications, where no configuration changes are required,
    you
    do not need to use the console port on the workgroup switch.
    The console port connector pin assignments are described in Table 1-2.
    For information about connecting a terminal to the console port, refer to
    Chapter 2, "Installing the BayStack Ethernet Workgroup Switch."
    To connect a terminal to the console port on the workgroup switch, attach
    one
    end of a straight-through serial communication cable to the console port of
    the
    workgroup switch and connect the other end of the terminal cable to the
    RS-232 port on the terminal or PC.
    The BayStack Ethernet Workgroup Switch console port uses a DB-9 male
    connector and RS-232 signaling with the following default parameters:
    .. VT100 terminal emulation mode
    .. 9600 baud
    .. 8 data bits
    .. No parity
    .. 1 stop bit
    .. Flow control disabled
    For console port connector pin-out information see Table 1-2 on page 1-5 of
    Chapter 1, "Overview of the BayStack Ethernet Workgroup Switch."
    Good luck
    Alex
    www.sffh.co.uk
    www.ebayfaq.co.uk
    Dr Zoidberg, Feb 7, 2005
