FOAK: Another Telly Question
Discussion in 'UK Motorcycles' started by Higgins@work, Jan 12, 2009.
  1. Higgins@work
    Higgins@work Guest
    I bought 40" of HD loveliness last weekend and, so far, I'm very
    impressed even with the standard definition picture. I have the PC
    connected via the VGA port, at 1920x1080, for watching Blu-Ray and HD
    satellite broadcasts and, to me, that also looks good.
    So, am I likely to gain any benefit from spending an arm and a leg on
    a DVI-HDMI adapter cable to replace the VGA connection?
  2. Higgins@work
    Higgins@work Guest
    The HD version of AnyDVD. I already had the DVD version so paid for
    the upgrade.
  3. Using a(n) HDMI cable makes a world of difference between my PS3 and
    DVD player when I hook either up to my TV.
    They don't have to be expensive though, I bought cheapies from Amazon.
    DoetNietComputeren, Jan 12, 2009
  4. Higgins@work
    Dr Zoidberg Guest
    A ten quid cable is more than sufficient to show a big improvement over VGA
    Dr Zoidberg, Jan 12, 2009
  5. Higgins@work
    Gyp Guest
    In message
    Huge difference.
    I bought a "1m 50cm PRO-2 HDMI to DVI Cable/Lead v1.3b HD 1080p 5ft"
    Gyp, Jan 12, 2009
  6. Higgins@work
    Higgins Guest
    Compared to what? Peritel?
    Higgins, Jan 12, 2009
  7. Higgins@work
    Higgins Guest
    Even when the resolution is set to 1920x1080?
  8. Compared to whatever cable types I used previously - ie component or
    scart.
    Well, that is HD quality, so a digital cable won't lose half of the
    data along the way. or something.
  9. Higgins@work
    Dr Zoidberg Guest
    Yep , we have a bunch screens at work driven by dvi-hdmi cables and they
    look fine with leads from ebuyer.
    Dr Zoidberg, Jan 13, 2009
  10. Higgins@work
    HDCP works over DVI (and DisplayPort and GVIF and UDI) as well as HDMI
    darsy, Jan 13, 2009
  11. Higgins@work
    Catman Guest
    Ditto my Mac Mini > TV.
    www.cuore-sportivo.co.uk
    Catman, Jan 13, 2009
  12. Higgins@work
    Dr Zoidberg Guest
    The only problem we had was with longer runs.
    Over 5m with a cable joint we started to get sparklies , but swapping to a
    better quality cable cured that.
    On 20m runs we had to use a signal amplifier close to the screen to be able
    to get 1080p - without we'd only get 720p with sparklies.
  13. Higgins@work
    Higgins Guest
    Hah, picked up an adapter cable today and, though set to 1920x1080, the
    picture is runs off the edges of the screen and ne combination of
    settings seems to improve matters.
    Arse.
    Higgins, Jan 13, 2009
  14. Higgins@work
    Higgins Guest
    You're absolutely right, cheers.
    I suppose I should really RTFM.
  15. Higgins@work
    Dr Zoidberg Guest
    As you say 40" I'm guessing it's a Sony , so you want the "full pixel"
    option in the display area setting
    Dr Zoidberg, Jan 14, 2009
