FOAK: Angle grinder right?
Discussion in 'UK Motorcycles' started by Pete Fisher, Nov 26, 2009.
  1. Pete Fisher
    Pete Fisher Guest
    The upgrade to the front brake on the YZ250 for hill climb use was going
    swimmingly this morning. EBC 280mm floating disc and MX-S sintered pads.
    Took me a while to figure out how the new caliper mounting bracket is
    fitted and I'm more used to Brembo than Nissin, but I got there in the
    end.
    So the moment of truth. Spin the front wheel (the original 21 inch at
    the moment until I have one rebuilt to 17 x 3.50). Clackety-clack-clack,
    like the days when you used to attach a lolipop stick in the forks of
    you push bike to make a motor noise as it twanged the spokes.
    Careful examination reveals that a few of the lobes on the wavy disk are
    making light contact with the pin on the caliper that one pad locates on
    and also allows the caliper to move from side to side a bit. 6 out of
    the 18 lobes. Marked the offenders with a dry marker to find them
    randomly distributed - so not an obvious oval disc.
    I could send it back and get a replacement, but there is every chance
    another may be the same. It's only a gnat's cock too much metal on the
    offending lobes. I could grind a slot on the pin (not a good move I
    suspect) or fettle the disc to ease the tight spots. One has already
    succumbed to the merest hint of dressing with a fine file, but before I
    let rip on the other 5 with an angle grinder, "nothing could possibly go
    wrong", could it oh FOAK?
    | Pete Fisher at Home: |
  2. Pete Fisher
    Beav Guest
    I'd probably start with some sandpaper on a flat surface (a piece of planed
    timber) myself rather than jump right in with the angle grinder.
    And if removing a gnats whisker from the offended pin is even remotely
    possible, that's where I'd start. A pin is a midge cheaper than a disc after
    all.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Nov 30, 2009
  3. Pete Fisher
    Pete Fisher Guest
    Too late. I reckoned it shouldn't be too risky as long as I didn't mark
    the braking surface. I took it very carefully and kept checking after
    each smidgen of metal was removed from the offending lobes, then checked
    for rough edges once the clattering was eliminated. Spinning smooth as
    silk now and the new pads don't seem to grab on gentle application.
    First run up Hartland then braking hard after the finish could be the
    proof of the pudding. I'm hoping, however, to get some time on the
    Haynes test track before then to sort out suspension, gearing and
    jetting on both the YZs and also give the lad a feel for riding his 85
    with sticky tyres on tarmac. I'll give the date sometime in February or
    March on here in case anyone else wants to come along for a a bit of
    fun. If we can sign up 15 bikes it becomes quite a good deal to have
    exclusive use of the circuit (such as it is) for a day.
    Pete Fisher, Nov 30, 2009
