FOAK : 6mm Allen Driver 3/4" or 1/2" Socket ? Anyone ?
Discussion in 'UK Motorcycles' started by Brownz \(Mobile\), Apr 14, 2009.
  1. Two questions really....
    1. Anyone have a sturdy 3/4" or 1/2" Socket type allen key of the 6mm
    Flavour, the type you use with a socket wrench.
    2. BMW K100RS 8v 1989 fitted with Showa forks - I shouldn't need to remove
    the upper fork legs from the headstock to change fork seals and replace the
    fork springs should I ?
    I'm off oot now for a beer as I'm pissed off at not being able to get the
    allen bolt out at the base of the fork that holds the stanchion springs etc
    to the upper fork leg.
    Back in a couple of hours.
    Hurrumph.
  2. Brownz \(Mobile\)
    antonye Guest
    antonye, Apr 14, 2009
  3. Brownz \(Mobile\)
    crn Guest
    I have a 3/8 set here near Weston Super Mare, not sure how far that is
    from you.
    crn, Apr 14, 2009
  4. Brownz \(Mobile\)
    Yeah. Probably. I'll check in the morning.
    Collect it at the bosm.
    Andy Bonwick, Apr 14, 2009
  5. Brownz \(Mobile\)
    platypus, Apr 14, 2009
  6. Brownz \(Mobile\)
    Just swing by your nearest Halfords and buy one. They sell them
    individually or as a set.
    ogden, Apr 14, 2009
  7. Brownz \(Mobile\)
    Gyp Guest
    Yes, and will be driving from Glos to London tomorrow if that's any help?
    Gyp, Apr 14, 2009
  8. Ahh, schweet, ta everyone, there is a local Halfrauds just 10mins from me,
    so I think its something worth investing in.
    Thanks for all your offers everybodypeeps.
    Brownz \(Mobile\), Apr 15, 2009
  9. Brownz \(Mobile\)
    geoff Guest
    I expect so - I'll check tomorrow
    geoff, Apr 15, 2009
  10. Brownz \(Mobile\)
    Simon Wilson Guest
    I'm sure I've got one if you get stuck.
    Simon Wilson, Apr 15, 2009
  11. Just picked up a set - 14 notes from halfrauds for a 3/4" set of bits,
    I just hope they are long enough to reach the bolt in the bottom of
    the fork stanchion.
    browniebrownz, Apr 15, 2009
  12. Brownz \(Mobile\)
    Eddie Guest
    3/4"?
    3/8", surely? Haven't you got any extension bars?
    Oh, and you do realise that you'll probably need something to hold the
    damper rod (inside the stanchion) in place, don't you?
    Eddie, Apr 15, 2009
  13. Brownz \(Mobile\)
    Eiron Guest
    What's wrong with friction, inertia and a rattle-gun?
    Eiron, Apr 15, 2009
  14. Brownz \(Mobile\)
    Eddie Guest
    Nothing, but I'm guessing that if he didn't have any hex bits, he might
    also be lacking in the power tools department.
    Anyway, I normally make up something to hold the damper rod using a
    selection of extension bars and socket adapters.
    Eddie, Apr 15, 2009
  15. Brownz \(Mobile\)
    zymurgy Guest
    What's wrong with a bit of sharpened broom handle ?
    Paul.
    zymurgy, Apr 15, 2009
  16. Brownz \(Mobile\)
    zymurgy Guest
    Yebbut think of the torque you could put through 6mm allen key with a
    3/4 breaker bar.
    I have a set of 3/4 stuff, left over from my HGV specialisation [1]
    days. Brutish it is.
    Paul.
    [1] Which I graduated in, but never actually used in anger ...
  17. Brownz \(Mobile\)
    Eddie Guest
    A pointed stick?
    Been there, done that. Waste of a perfectly good broom handle, IYAM.
    You *dirty* old man.
    Eddie, Apr 15, 2009
  18. Brownz \(Mobile\)
    Eddie Guest
    .... for a very short time before the bit shattered, anyway.
    Eddie, Apr 15, 2009
  19. Heh.... yeh, I meant to type 3/8" not 3/4" !
    No rattle guns in this garage I'm afraid, a compressor and airtools
    collection would be nice, but I can't justify it at the mo.
    To stop the stanchion turning you take the front spindle and nip it up
    in the clamp leaving yourself enough room to get the allen key in (or
    so the haynes manual says).
  20. Brownz \(Mobile\)
    Simon Wilson Guest
    Rattle gun also available here.
