I have a 2000 suzuki katana gsx750f and it is having some trouble. It floods...a lot. So, at first I thought carbs...but now I'm not so sure. I think it may be the vacuum actuated fuel valve or possible the tank vent. So, I'll tell you all what I did to investigate and all advice is appreciated. I started by removing the tank. When the fuel line was disconnected, gas sprayed (with decent pressure) out of the main fuel line. Shouldn't the valve have prevented this? I think the tank may be over pressurizing and forcing fuel past the shut-off valve. It is supposed to be actuated by carb vacuum, so I figure the spring is pretty weak and an over pressurized tank would fairly easily get by this valve. Is this a correct assumption? Once I opened the gas cap to relieve the pressure, the valve stopped the flow of fuel on its own. Next, I removed the airbox after draining the fuel out of it (severe flooding). Then, With the carbs exposed, I tried a trick i read about here. i hooked a little piece of fuel line to each of the drain nipples on the four float bowls, pointed the hose up and opened the drain valve to check the float levels. They all looked pretty even. I kept fuel in the line from the tank to ensure that a bad float would show here. It didn't as far as I can tell. So, I pulled the carbs, set them on the work bench at approximately the same angle and let them sit, with fuel in the fuel rail, to see if any of the carbs was leaking gas somewhere. I didn't see any. Next I removed the plugs, and eureka! plug 2 was darker than the rest, so i assume this is the flooding cylinder, as the plug was brown. So, I know which cylinder, but now why. Checked the carbs again, still no gas leaking out. Here is my theory, and please tell me what you think. I think the gas tank is overpressurizing. The gas cap threaded and comes out pretty hard sometimes. I think that this over pressure is forcing fuel past the fuel valve and past a float valve, flooding the cylinders and airbox. Is this possible? How much pressure should be on the tank? How do i check it? Is the vent supposed to regulate pressure? I am hoping to avoid taking the carbs into a shop due to the expense. I would like to investigate all other possible causes first. Thanks for everyone's help!
