Flashed for 42mph in a 40?!
Discussion in 'UK Motorcycles' started by Two stroke smoke, Dec 21, 2004.
  1. Driving home last night in the car (too bloody cold and slippy for the bike)
    Coming up to a gatso that's been there for at least a year and I know all
    about it. Car in front jumps on anchors and slows to 35mph. I thought
    bugger this, it's a forty limit and move to outside lane (dual carriageway).
    I passed said car and then got the old double flash in the mirror.
    Now, I checked my speed just before passing the camera and then as it
    flashed me. Not once did I see the needle on my speedo pass 42mph. So
    what's that all about then? Have I confused the thing? I mean 42 is taking
    the piss, surely I would have grounds to fight it. I've passed this camera
    at that speed nearly every day since it was put up.
    Have cameras been known like the old radar guns to give completely false
    readings? What if it said I was doing 50 or 70 or something silly?
    What does the FOAK reckon then?
    The car's a Nissan 1L Micra so it's hardly going to tear up the tarmac. So,
    it was £50 and I needed wheels.What does the FOAK reckon then?
  2. Two stroke smoke
    tallbloke Guest
    You should have noted the number plate of the car you overtook as a
    witness to how slowly you crawled past. 10% speedo error would put you in
    the clear anyway. Good luck. Of course they might not summons you anyway.
    Call the taste police.
    tallbloke, Dec 21, 2004
  3. Two stroke smoke
    tallbloke Guest
    Does the 10% error allowance no longer apply then? How would the camera know
    whether his speedo was spot on or underreading by 9.9%?
  4. Two stroke smoke
    dwb Guest
    Not under the new prosposals going through - no - speeding will be speeding.
    But you'll only get 2 points. Yay.
    dwb, Dec 21, 2004
  5. Two stroke smoke
    tallbloke Guest
    I'm pretty sure it's firmer than that, BIMBW. SWKWBAS.
    But sometimes they do, and the motorist is given a 10% of leeway under the
    law, because he has no way of telling if his speedo is a bit out.
  6. Two stroke smoke
    dwb Guest
    By law they must not under read - we've done this one a few times on here in
    the past I believe.
    They were ACPO(is that right?) guidelines - never any kind of law AFAIK.
    dwb, Dec 21, 2004
  7. Two stroke smoke
    Odds are it was empty.
    If it were me, and an NIP arrives, I would contest it, swearing that I
    was aware of the camera and my speedo was bang on 40mph, the car is
    road legal/mot'd [1] and I want the speedo tested.
    [1] none of which has anything to do with a working speedo, but worth
    throwing a bit of rhetorical dust about.
    Champ, Dec 21, 2004
  8. Two stroke smoke
    tallbloke Guest
    Surely that's a matter the police would have to take up with the
    manufacturer rather than the motorist, assuming the motorist hasn't
    modified the vehicle in such a way as to cause the speedo to under read,
    by fgitting bigger wheels and or tyreprofiles than standard.
    Ah ok
  9. Two stroke smoke
    Big Tony Guest
    I wouldn't worry about it. There is nothing you can do anyway until you
    receive something through the post, which I doubt you will. If you do
    receive something, keep hold of it - including the envelope it came in - and
    have a look at www.pepipoo.com before you do anything else.
    Big Tony, Dec 21, 2004
  10. Thanks, bookmarked.
  11. Two stroke smoke
    Steve Parry Guest
    In
    I thought the non compulsory "recommendation" from the Government to the
    ACPO was 10% plus 2 mph ?
    Steve Parry
    http://www.gwynfryn.co.uk
    http://www.arrivedeprived.org.uk/
    K100RS SE
    F650
    (not forgetting the SK90PY)
    Steve Parry, Dec 21, 2004
  12. Two stroke smoke
    tallbloke Guest
    Ta for the clarification
    Sounds like the OP shouldn't be getting a NIP then.
  13. Two stroke smoke
    That was my understanding too.
    Champ, Dec 21, 2004
  14. Two stroke smoke
    Two stroke smoke emerged from their own little world to say
    You say it was a dual carriageway. Was the camera in the central
    reservation? Was a vehicle coming the other way? Some older cameras, when
    the film has run out, are triggered by oncoming vehicles.
    wessie, Dec 21, 2004
  15. Two stroke smoke
    Ooh - good explanation. I reckon that could be it.
    Champ, Dec 21, 2004
  16. Two stroke smoke
    Eiron Guest
    Two stroke smoke wrote:
    How fast was the top of the wheel travelling?
    Perhaps the gatso picked up the tasteful reflective Christmas
    decorations you fixed on the wheeltrims.
    Eiron, Dec 21, 2004
  17. Does that include his daughter?
    True in theory.
    Mick Whittingham, Dec 21, 2004
  18. Two stroke smoke
    Steve Parry Guest
  19. Nope, nearside kerb. Thought had croosed me mind.
  20. If there are 2 vehicles in the photograph they will usually not bother
    to procede with a case.
    It gets too messy and time consuming because you will claim the other
    car undertook you.
    It has been said that cases where the accused fights back usually get
    dropped.
    ColonelTupperware,
    spouting bollocks on Usenet since 1997
    Usenet FAQ at
    http://www.its.caltech.edu/its/services/internetapps/news/news2.shtml
    UPCE FAQ at http://upce.org.uk/ UKRM FAQ at http://www.ukrm.net/faq/
    Colonel Tupperware, Dec 21, 2004
