FJR Buying advice - thanks
Discussion in 'UK Motorcycles' started by Ian, Apr 11, 2011.
  1. Ian
    Kevin Guest
    Both the US FJR forum - http://www.fjrforum.com - and US Concours
    (Kawasaki GTR) forum - http://forum.concours.org/ - seem to be
    inhabited by very knowledgeable and helpful people but then I guess
    you'd have to rather warped to want to put an extended swing arm on
    either of those bikes.
    Kevin (who knows someone is going to respond with a link to a picture
    of an FJR or GTR with an extended swing arm...)
    Kevin, Apr 11, 2011
  2. Ian
    Andy Bonwick, Apr 11, 2011
  3. Ian
    I'm neither fat, nor bald tvm.
  4. Ian
    I joined a UK based GS forum which has provided much useful information, a
    few friends off the internet and the knowledge of why not to buy a BMW
    motorcycle made after about 2003.
    wessie, Apr 11, 2011
  5. Ian
    No, sir just needs to ride it a bit more and get used to the race
    crouch. It doesn't take long to adjust.
    When I'm old and past it, then I'll look at something more comfortable.
    ogden, Apr 11, 2011
  6. Ian
    des Guest
    I joined UKRM.
    des, Apr 11, 2011
  7. Ian
    Higgins Guest
    That's why your name rings a bell. SVRider.com?
    Higgins, Apr 11, 2011
  8. Ian
    davethedave Guest
    Sir just needs to go faster. The wind blast on the head and chest provide a
    lot of support.
    davethedave, Apr 11, 2011
  9. Ian
    My body's just not really used to it - I used to ride a sportsbike every
    day and it seemed normal. Now I use the KTM as a daily commuter and the
    GSXR only comes out for special occasions.
    I'll get used to it again.
    ogden, Apr 11, 2011
  10. Ian
    Salad Dodger Guest
    Most og the GL forums are a mine of info, and helpful advice, as are
    the CBX ones.
    The CB13 one seems a little sad by comparison.
    Salad Dodger, Apr 11, 2011
  11. Ian
    Mark Olson Guest
    Yep, I was on there, as well as a/the Yahoo SV mailing list and
    the Google Groups SV/DL group, too.
    Mark Olson, Apr 11, 2011
  12. Ian
    Thomas Guest
    Mark -
    I remember lots of comments about the factory fixing various FJR
    problems, and that one shouldn't buy early models and opt for the
    latest if possible. What year did that advice became obsolete?
    Thomas, Apr 11, 2011
  13. Ian
    Mark Olson Guest
    The 2006 and later Gen II models got rid of the ticker problem, and addressed
    the 'heat problem' but added a couple new problems that the earlier models
    didn't have. But not all Gen I bikes will become tickers (Yamaha fixed most
    of the tickers in the USA, but I have no idea if they did in Europe) so if
    he's got a good one he's really good to go. Even if it turns out he's bought
    a ticker, or it turns into one, all it really means is, the exhaust valves and
    valve guides need to be replaced. Not cheap, but a relatively straightforward
    repair.
  14. Ian
    Ian Guest
    The seller said he'd had the valves done, but I didn't ask to see
    evidence that the work had been completed. I'll double check before
    completing the sale though.
    Cheers
    Ian, Apr 11, 2011
  15. Ian
    Mark Olson Guest
    "Had the valves done" usually mean the valve clearances have been checked
    and adjusted if needed. A much different thing than rebuilding the head.
    But if he was indeed referring to replacing valve guides and valves, you
    will be just fine with a Gen I.
  16. Ian
    Ian Guest
    What's the ballpark on the replacement job, if it hasn't been done?
    Ian, Apr 11, 2011
  17. It's a biggish job. Head off, exhaust valves replaced with new guides and
    a new redesigned oil stem seal. But I really wouldn't worry about it. Mine
    ticks and has done for years and nearly 100k km. It's only a noise and has
    no influence on performance (dyno tested proof if required). When it gets
    really really bad you get oil coming out of the exhaust. For some reason
    the US made a much bigger hoohah about it than over here.
    I can supply links if you really want the full paranoia effect.
    Jeremy Robinson, Apr 11, 2011
  18. Ian
    That doesn't happen on the SV forum, as most of them are switching to
    Street Triples and GSXRs
    Lozzo
    they churn out)
    Lozzo, Apr 11, 2011
  19. Ian
    Ian Guest
    Provided there's no performance loss, I'll probably wing it. The bike
    has 15k miles on it and I've asked the vendor to clarify the work he's
    had done, but to be honest, they seem like a bullet-proof bike, which
    is why they were on my list in the first place. I need it to start
    every day and do the ringroad run to work, come hail or shine. It'd be
    a shame to put a new FJR on that run, but an 04? Ticker or not, it's
    probably going to get me to work so it ticks that box.
    Ian, Apr 11, 2011
  20. Ian
    Mark Olson Guest
    No idea, really. Any competent machine shop that does cylinder head
    rebuilding can do it.
    I just did a search on fjrforum.com for this topic and found this
    topic:
    "Question About Buying An Fjr, Cost To Fix Ticker"
    http://www.fjrforum.com/forum//inde...st&p=790879&hl=+valve++job++cost&fromsearch=1
    If the link above doesn't work, the most informative response by
    ionbeam is copied & pasted below my comments.
    Keep these points in mind:
    If it doesn't tick now, you're probably just fine.
    If it ever does start to tick you can ride it for a long
    time before you have to do anything about it.
    You can save a huge fraction of the cost by removing &
    replacing the cylinder head yourself, and carrying the head
    to an independent cylinder head rebuilding shop.
    Remember this is not something that happens to every Gen I
    bike. Most will never develop the problem.
    ==========================fjrforum post============================
    [Poster] ionbeam
    Group:Members++
    Gender:Male
    Bike: 2004 ABS (N. America)
    Posted 21 September 2010 - 03:40 PM
    Expect repair cost to run in the $1.4k to $1.75k range if your dealer
    does 100% of the work. You can reduce that amount by stripping the
    bike down and putting it back together yourself. The more you do,
    the more you save. There is a chance that Yamaha may still pick up
    some or all of the cost.
    If you are looking at an '03 your odds of it being a ticker is very
    likely <20%, much less than that if it is an '04 and very, very
    unlikely for an '05. The premature wear of the valve guides due
    to stem seals being too tight takes a long time. You can ride the
    motorcycle until oil comes out the exhaust and it will still run ok
    and be reliable.
    Not knowing the model year or miles it's hard to advise much more. The
    true dealer check for a 'ticker' is to pull the head pipes and look
    for traces of engine oil. The duffers check is to put a long metal rod,
    long screwdriver, etc on the exhaust header right at the cylinder head,
    at cyl #1, then with the engine running put your ear on the improvised
    mechanic's stethoscope and listen for sharp metallic rattling. This
    can be done with the faring still on. If the bike is very low mileage
    it is unlikely either of these checks will show anything.
    If the deal is good and the bike is clean, I think it is worth
    the risk.
