Problem I had with the bike is 3:rd gear jumping out and it got worse by time. I have now split the crankcase and disassembled the two transmission shafts. I was almost certain to find wear on gears and dogs on the gears but they look ok. At least what I can see. I have never worked on a bike transmission before but with Haynes manual it was easy to take it apart. Can someone tell me what I'm looking for here? Dogs and gear-tooths looks fine. 3:rd/4:th gear look darker than the other, almost like it got hot or something. Maybe it should look like this. The dogs "hook" in to the other gears like they should but they tend to go apart if you put some force to them (they don't lock themselfs together harder). Do I need to replace 3:rd gear pairs even if they look ok? Could the problem be in the gear change drum or the three forks? Hope someone can help me out here :) Best Regards, Henrik Olofsson Sweden
