Fitting my new rear tyre, what a ...
Discussion in 'UK Motorcycles' started by Donnie, Aug 16, 2009.
  1. Donnie
    Donnie Guest
    ...... fucking ballache!
    Did the front one a few weeks back on the CB, not too much hassle but
    it wouldnt seat on the beads and i brought it to my friendly localish
    place and he sorted it and then balanced it too.
    Did the rear one yesterday, same bleeding problem, I dont have access
    to a proper compressor which doesnt help so thought id try the local
    garage, theres one with a proper trigger air line rather than one of
    those ones you set the pressure to. of course its broke!
    so next one, i set it to 50 psi, (label says dont exceed 57) and it
    seemed ok, then i let it down and it was obvious that it wasnt sitting
    quite right on the rim, ie the out of the tyre wall wasnt coming right
    out the the inner of the rim :-(
    All this was done with the valve removed then with it back in, no
    change.
    So, plan is bring the wheel to my friendly local, though i may try the
    new place in kempston in the morning as they open at 8am, or the other
    place i had the front done at.
    But is there a knack or some other trick im missing?
    As an aside, i noticed that the rear wheel had no balancing weights on
    it and looks like it never did, is this common and the fronts just more
    important? It rode fine.
  2. Donnie
    You are using tyre soap, aren't you?
    Krusty, Aug 16, 2009
  3. Donnie
    YTC#1 Guest
    Anger therapy
    YTC#1, Aug 16, 2009
  4. Donnie
    Donnie Guest
    Krusty said:
    yep
  5. Donnie
    Greybeard Guest
    Why??
    Water soluble lubricant, and inflate.
    The magic does the rest.
    Greybeard
    FLHR -03 UK (95 cu-in Stg 2. Big Boy 2!)
    Garmin Zumo 550, To get me home!
    ukrm@foxtails[dot]co[dot]uk
    Greybeard, Aug 16, 2009
  6. Donnie
    Adrian Guest
    Sometimes the bead won't seat well enough to actually hold air. A good
    bounce on the floor a few times often helps, but sometimes a hefty
    twatting is needed.
    Adrian, Aug 16, 2009
  7. Donnie
    Donnie Guest
    Adrian said:
    hmmmmmmmmmm
    when i described inflating the tyre to 50psi it is actually holding air.
    but when i then deflate it, part of the tyre moves back into the well,
    does that make sense?
  8. Donnie
    Adrian Guest
    Sounds like you need to take the pressure up a bit higher to get it to
    seat properly. Mebbe a slather more lubricant if you can?
  9. Donnie
    Donnie Guest
    Adrian said:
    Definite. but the wall of the tyre seemed twisted as it didnt all seem
    to be coming out of the well completely. Its difficult to describe.
    if you imagine the wheel flat on the ground. then see where it says
    "Bridgestone" on the wall of the tyre.
    ok, if you imagine a line underlining the work bridgestone, this line
    should be an equal distance from the edge of the rim say 1cm.
    if i inflate to 50psi, the bottom of the b is right on the rim, the e
    on the other end is 1 to 1.5 cm off the rim. not sure if that makes
    sense.
    i think you may have hit the nail on the head with that.
  10. I generally find it needs 60+ psi to seat properly.
    The Older Gentleman, Aug 16, 2009
  11. Donnie
    crn Guest
    Old trick used by roadside truck tyre fitters.
    Two teaspoons of petrol [1], a blast of air to vaporise, throw match.
    BLAM.
    Tyre neatly beaded.
    [1] About an eggcup for a truck tyre so 2 teaspoons should be OK for a
    bike tyre.
    crn, Aug 16, 2009
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    typed
    Please video this if you try it.
    go and talk to the Catholics.
    Wicked Uncle Nigel, Aug 16, 2009
  13. Donnie
    Donnie Guest
    said:
    LOL, yes ive seen the youtube clips LOL
  14. Donnie
    Donnie Guest
    The Older Gentleman said:
    hmmm think ill try a load more tyre soap tomorrow and 60psi then :)
  15. Donnie
    I don't know why you bother doing them yourself when Chris at Bedford
    Bike and Car Centre on Kingfisher Wharf charges a minimal amount to fit
    tyres you take in to loose wheels.
    Lozzo, Aug 16, 2009
  16. Donnie
    Greybeard Guest
    I see,
    Never had that problem. The bouncing sorts it, but you doo need a high
    volume compressor to seat the bead sometimes.
    Greybeard
    Greybeard, Aug 17, 2009
  17. Donnie
    bod43 Guest
    bod43, Aug 17, 2009
  18. Donnie
    Donnie Guest
    Lozzo said:
    Wanted to see if i could do it i guess, think ill go to Bike and Car
    centre next time then.
    Donnie, Aug 17, 2009
  19. Donnie
    Adie Guest
    I'd highly recommend Bedford Wheels
    http://www.bedford-wheels.co.uk/
    Adie
    UKRM FAQ: http://www.ukrm.info/faq/
    YZF-R1 : FZ1N : RD350LC
    (anyone would think I was partial to Yamahas)
    keeper of the FAQ for my sins
    MRO#11 BOTAFOF#7 BOTAFOT#130 DIAABTCOD#17 MIB#24 YTC#16
    BOB#15 ex-UKRMMA#22 BOMB#11
    Adie, Aug 17, 2009
  20. Donnie
    Donnie Guest
    Adie said:
    ooooh, christ thats only half a mile from my front door!
