First spill (bit long)
Discussion in 'UK Motorcycles' started by Geo, Mar 25, 2008.
  1. Geo
    Geo Guest
    I could ramble about how the road had bumps, no grip,the turn is the wrong
    angle, the wind was too strong etc etc, but I knew all that as I ride every
    day to work. I was taking the exit from the motorway after I stupidly
    overtook "just one more car" before turning, got in faster than I should
    have (that's a total speed of about 65mph, nothing really fast), didn't
    manage to brake enough, went wide and said hello to a couple of shrubs.
    Nothing broken, bike was good enough to ride further. My problem is that the
    bike (a Suzuki Freewind) most probably had enough reserves to brake better
    and/or take the turn at that speed, but I didn't dare/know how to use them
    so rather than turning the way the bike could, I turned the way *I* could,
    knowing full well that it wasn't good enough. I generally can't trust the
    bike much, it's mainly the front that feels remote. I've lost grip in front
    a couple of times and it was rather unexpected (I mainly blame the tarmac
    and oldish tyres), but only for fractions of a second and the bike recovered
    from it without much fuss. The main problem here is the asphalt which would
    often grip better if it were waxed and polished, but either way, I need to
    improve.
    So, what say all you experts, any suggestions on how I can bring myself to
    at least try and push the bike closer to its limits without falling on my
    arse too much (I can already do that without pushing, thank you)? I tried
    doing it gradually, but losing grip when you don't expect it screws up the
    learning process.
    Getting a less pikey bike is not a suggestion atm, it does all I need it to
    do very well and cheaply.
    Geo
    Geo, Mar 25, 2008
  2. Geo
    Geo wrote:
    Clumsy ****.
    platypus, Mar 25, 2008
  3. Geo
    Catman Guest
    Geo wrote:
    Did you really go too fast, or did you fixate on the target corner and
    ride striaght into it?
    www.cuore-sportivo.co.uk
    Catman, Mar 25, 2008
  4. Geo
    Cab Guest
    Geo wrote:
    <snippo>
    Clumsy fucker. At least you and the bike are still around.
    Cab, Mar 25, 2008
  5. Geo
    Geo Guest
    I suppose a fair bit of the latter. I *felt* I was going too fast so I think
    I had already mentally accepted the fact that I would crash rather than
    telling myself to try and brake/turn a bit harder. The bike might have made
    it or at least I would have dropped it trying, rather than being pissed off
    at myself for falling like an idiot. I think I also got scared of the
    complications of a potential mid-road spill with the car following me. What
    I really should have done was not overtake that last car and I bloody well
    knew it while I was doing it.
    I wasn't objectively fast, but I was apparently going faster than a person
    of my experience/capabilities should have. The turn's a rather unpleasant
    one (abrupt exit from the motorway, 160 degrees, bumps on the
    entrance/braking zone, not much grip in general), but should be lots of fun
    for those who like drifting.
    Geo
    Geo, Mar 25, 2008
  6. Geo
    Beav Guest
    A Bikesafe course? Or something similar.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 25, 2008
  7. Geo
    Geo Guest
    Hurray for protective gear on me, bars on the bike and soft earth next to
    the turn. Only things that got damaged were a footpeg, a mirror and my ego.
    Geo
    Geo, Mar 25, 2008
  8. Geo
    Geo Guest
    I'm actually doing that to some extent (a bit like minimal
    counter-steering), but although it makes the bike turn easier, it doesn't
    give me a very good feeling (front's a bit wobbly sometimes and feels like
    it's about to lose grip). The only times the bike feels more solid is when I
    place all my weight in my outer foot and press with the knee to the inside
    at the same time. Extending the inner leg supermoto-style makes it even
    better, but I don't like looking like a twat and I like having access to the
    gear/rear brake levers.
    Geo
    Geo, Mar 25, 2008
  9. Geo
    Geo Guest
    That would definitely be a good idea, but I'm not sure I'll find anything
    around here (Crete). I will have a look anyway.
    Geo
    Geo, Mar 25, 2008
  10. Geo
    TD Guest
    I'm not an expert, but how about a track day? I'm hoping a few of those will
    give me a clue.
    TD, Mar 25, 2008
  11. Geo
    TD Guest
    Did you say the tyres are crap? If so, that could be a good reason for the
    lack of feel.
    TD, Mar 25, 2008
  12. Geo
    Cab Guest
    Safety Nazi :)
    Cab, Mar 25, 2008
  13. Geo
    Geo Guest
    Aye, that was already among the "to do" list. They have plenty of thread
    left but they don't look that fresh and have been behaving somewhat worse
    the last couple of months. Then again maybe I got more cocky the last couple
    of months.
    Geo
    Geo, Mar 25, 2008
  14. Geo
    Geo Guest
    Heraklion, where the sun is bright and the roads are crap.
    Geo
    Geo, Mar 25, 2008
  15. Geo
    Geo Guest
    Aye, unless you fancy go-karting.... Even then, there's not that much on
    offer I think.
    You could easily replace "Crete" with "Greece" altogether and still wouldn't
    be far off.
    Geo
    Geo, Mar 25, 2008
  16. Geo
    Catman Guest
    That might be the most important thing to learn, then.
    I *doubt* it's quite that bad, but ISTBC. At least you're still around
    and learning.
    Where is it, out of interest?
  17. Geo
    Catman Guest
    For some reason, I thought you were in the UK. Your roads may well be as
    bad as you claim :)
  18. Geo
    Rudy Lacchin Guest
    Apologies in advance if I'm telling you stuff you already know but were you
    braking and cornering at the same time? Are you aware how weight is
    transferred to the front tyre under deceleration just as it's struggling to
    cope with the reduced grip caused by cornering? Should I shut up now?
    Rudy Lacchin, Mar 25, 2008
  19. Geo
    Geo Guest
    Greek roads are generally rather poor, but Heraklion is just awful. Of all
    the places I've been in Greece, I haven't seen so many problematic areas in
    so little space. There's places where the asphalt isn't a year old and it's
    already slippery as hell. Not to mention all the cracks/bumps/potholes in
    older roads.
    The main reason is allegedly that the minerals used aren't as
    abrasion-resistant as they should be (asbestolithic rather than e.g.
    granite-basalt from what I remember) and get a lovely sheen within less than
    a year - at least that's what an article claimed several years ago. Add
    mediocre maintenance, very high temperatures in the summer and often shoddy
    manufacturing/repairs and you get the idea.
    It's a shame, as the weather here's good enough to ride 300 days a year
    without waterproofs.
    Geo
    Geo, Mar 25, 2008
  20. Geo
    Geo Guest
    I am *very* careful when braking during cornering and I generally avoid it
    altogether. That was part of the problem, as I ran out of "straight line"
    early and pertty much stopped braking while cornering. I didn't lose
    traction, I went wide and ran out of road.
    Geo
    Geo, Mar 25, 2008
