Finished. Well, sort of . . .
Discussion in 'Classic Motorbikes' started by antony.adshead, Jul 12, 2006.
  1. It's ready for its MOT
    http://www.antony.adshead.dsl.pipex.com/the441.htm
    Just can't get a tickover. Static timed it using the flywheel plug
    hole. New 32mm Amal. I can't seem to get it to tickover smoothly at
    anything less than a rate that's little bit too hectic and the pilot
    jet is the only thing affecting things there. Try for less revs and it
    kind of has quite a long cycle of revving and slow-w-w-wly dying.
    Still, it sounds and feels like a lot of fun and I can't wait to get
    the thing rolling
    your, in a good mood (for now)
    Ants
  2. antony.adshead
    Paul - xxx Guest
    Paul - xxx, Jul 13, 2006
  3. antony.adshead
    JB Guest
    Nice work. Did you keep any pictures of waht the bike was like before you
    started and throughout the rebuild?
    JB
    JB, Jul 13, 2006
  4. Grimly Curmudgeon, Jul 13, 2006
  5. Lovely. I always thought the Victor Special was one of the nicest
    looking dirt bikes made.
    The Older Gentleman, Jul 13, 2006
  6. antony.adshead
    Well, that *does* look rather nice. Conga rats.
    Timo Geusch, Jul 13, 2006
  7. antony.adshead
    Fr Jack Guest
    That's nice!
    I have an ex-WD B40 in boxes, somewhere, but I haven't got the space,
    ability or cash to rebuild it. Pah!
    Cheers!
    Fr Jack
    B12S POTENTIAL LICENCE SHREDDER - AT GRIN FACTOR 10!
    FRJACKUKRM AT GMAIL DOT COM
    Fr Jack, Jul 13, 2006
  8. antony.adshead, Jul 16, 2006
  9. It seems a bit long. For now I've routed it for function, but will see
    if I can make it a bit less obtrusive as I go thru the fettling
    process. I've got bigger fish to fry right now
    Ants
  10. If you ever want to shift it, let me know. I quite fancy a B40 as a
    trials project
  11. Day 1 (Friday): Miles = >4, got the VS MOTed, got insured, rode it for
    a short while before the MOT test and it wet sumped. Got it home (with
    its MOT :) The tester just praised it a for a while then printed the
    form out!!) and removed one of the two crank breathers I'd put on. My
    reasoning was that the one way valve on the (10mm) breather had created
    such a vacuum in the c'case that it was hampering the return side of
    the oil pump. Rode a couple of miles that evening and all fine.
    Day 2 (Saturday) No bike business today
    Day 3 (Sun) Rode about 6 miles to the start of the West Riding Trial.
    All fine. Pootled about over the moors for 1/2hr and started to get a
    bit of misfiring, blue smoke and a little uncertainty at the rear
    wheel. Looked down and its peed its pants again. I was about 7 miles
    from home with half my oil not in the tank and a very hot engine.
    Didn't want to risk the slightly oily back tyre so I called Bob and got
    a van ride home. First thing I'm gonna try is getting rid of the
    remaining (6mm) rocker breather as this could have caused a negative
    pressure build up in the c'case.
    Strange other problem is my kickstart has gone really stiff. Looks like
    I've gotta get into the gearbox.
    It's a sunny day so I'm gonna take the rest of it off and mull over my
    problems.
    The joys of living with Victor!
