thanks again for all the previous help, patience, and indulgence as i get this bike into shape for the long haul. with a little luck, this'll be my last plea for help and i won't have to bother anyone further with remedial mechanical issues. to bring you up to date, i wanted to change leaky fork seals, so: i drained the forks, took the fender, fork brace, brake calipers, and wheel off. then i unbolted the fork sliders at the bottom, and they slid right off with the damper rod sticking out about ten inches from the bottom of the fork tube. (question #1: should it be sticking that far out? some of the stuff i've read makes me wonder about that.) to my surprise, i had none of the parts that the clymer's manual said i should have inside the slider. no bushings, no washers. the only things in the slider were the seal at the top and a ~1-inch tall spacer at the bottom. when i compared the new seals with the old, i noticed a big difference and called the parts guy. he said he'd given me the seals for the bmw made forks, and that unfortunately my forks are actually showa forks. i thought this might account for the difference between the clymer guide fork description and the real life situation i have before me. i then looked for info on the showa forks and found Tom Coradeschi's showa fork rebuild page on the ibmwr site ([URL]http://www.ibmwr.org/ktech/showa-fork-rebuild.shtml[/URL] .) not having taking apart the upper end of the forks, i don't have the firmest grasp of all the info in his explanation. i do, however, understand that according to his showa fork diagram (at [URL]http://www.ibmwr.org/ktech/showa-[/URL] fork-rebuild.gif ) i should still have some washers and bushings in the sliders. as i mentioned, i don't have any such parts in the sliders. question #2: i can't tell from the diagram whether the washer and bushing should fit in the fat part of the opening at the top of the slider. it doesn't appear that there is room for much more than the oil seal and the circlip. so should the washer and bushing sit inside the slider? that doesn't seem quite right either. question #3: i can't seem to find an authoritative statement on the proper assembly of the showa forks. what is the danger of forgoing the washer and bushing, as my bike's previous technician evidently did? would this contribute to the leaky seals and/or the soft ride? would it cause handling problems? question #4: once i decide how to proceed with respect to the innards, i'm planning on putting everything back together in the order i took it off. since i haven't moved the fork tubes, this should keep the front end properly aligned, right? question #5: somewhat unrelated: i figured i might as well do an oil change while i'm doing all this. i noticed a couple oily spots on the bottom of the oil pan, so i'm going to reseal that too. but with what? i've got a silicone sealant for motorcycles, but i don't know if it'll handle the heat that an oil pan gets. it doesn't have a temperature rating, but it's called permatex motoseal 1 ("ultimate gasket maker - gray.) what would a smart person use? i welcome and thank you for answers to any of these questions. much appreciated!
