Festive Fettling (quite long)
Discussion in 'UK Motorcycles' started by Oldbloke, Dec 22, 2003.
  1. Oldbloke
    Oldbloke Guest
    OK
    Thanks for that, they seem to have loads of stuff (we also need a front
    brake cable). I will deffo bookmark this site.
    Oldbloke
    2000 Honda CB500, 1991 Suzuki TS50 (m'boy's)
    BOTAFOT #140
    "He's like Robbo's chubby kid brother"
    Oldbloke, Dec 23, 2003
  2. I've got loads, if you let me know the diameter and the diameter of the
    'ole.
    The Older Gentleman, Dec 23, 2003
  3. Oldbloke
    Oldbloke Guest
    message
    Well, the diameter of the "shank" of the drain plug is about 9mm, and the
    diameter of the "flange" of the drain plug is around 15mm.(see diag)
    ______
    /______\ 15mm
    | | 9mm (ish)
    Oldbloke
    BOTAFOT #140
  4. I'll have a rootle[1].
    [1] It's like a furtle, only not as rude.
  5. Oldbloke
    christofire Guest
    I suppose life has to compensate you somehow.
    christofire, Dec 23, 2003
  6. An utterly amazing design. I mean, what possessed the designer to think
    of that one?
    The bearings get hot through friction and heat conducted along the shaft
    from the gears which are busily generating heat through friction on each
    other - bingo! - some grease melts and slowly, reluctantly finds its way
    (if the moon's in the right phase) into some spot where it might do some
    good. And then runs out again, to solidify on the gearbox wall.
    **** me - I wonder how long those 'boxes lasted.
    GS 850 x2 / SE 6a
    SbS#6 DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Dec 23, 2003
  7. Oldbloke
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Grimly Curmudgeon
    In all seriousnessnessness, what happens is that you check the level by
    removing a screw. If no oily stuff drippeth forth, you top it up with
    (IIRC) EP80. So there's usually *some* oil kicking about.
    And the boxes aren't usually turning very fast, or for very long,
    anyway. ;^)
    Nigel Eaton, Dec 23, 2003
  8. Many hardware stores are deeply disturbing. Grumpy old bastards in brown
    coats who look at you as if you know **** all.
    You must march up to the counter and loudly accost the nearest brown
    coat wearer with, "A pound of 4inch nails and be quick about it, my good
    man, and while you're at it, I'll have two dozen 5/8th annealed copper
    washers for my Black Shadow."
    GS 850 x2 / SE 6a
  9. It's just as well the survivors are only brought out for the odd summer
    day outing. They at least stand a chance of lasting for a few more
    years, only doing very low mileages.
    <cue somebody who used to ride to the whippet factory every day for 20
    years on his Enfield and only ever broke down once when his flat cap
    blew off>
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Dec 24, 2003
  10. Oldbloke
    deadmail Guest
    Strangely therapeutic?
    Nothing strange about it at all imo. I find working on bikes (on my
    own...) to be one of the most calming things I can do. Well bikes,
    cars, lawnmowers etc. basically anything that involves using handtools
    and thinking about 'mechanical' stuff.
    In an earlier job I used to install the predecessors of car-phones
    (system-4 'phones if anyone's interested) and in those days I was a lot
    calmer than I am now. Mind you, that could be due to a shitload of
    other stuff besides the fact I don't use tools on a daily basis anymore.
    deadmail, Dec 30, 2003
  11. Oldbloke
    Nigel Eaton Guest
    typed
    This is true. With one important proviso:
    There must be no pressure of the "I need this working by such-and-such a
    time to get to work / a leg over / the shops for food and beer / the
    pub" variety. Then it's a fucking pain.
    Nigel Eaton, Dec 30, 2003
  12. Oldbloke
    Ben Blaney Guest
    er... you know I just lobbed the bandit again...
    Ben Blaney, Dec 30, 2003
  13. It's never happened yet, has it?
    The Older Gentleman, Dec 30, 2003
  14. Oldbloke
    Oldbloke Guest
    <snip>
    So far it has been quite enjoyable fettling the small bike. However, my lad
    passed his CBT today which has put the pressure on, particularly seeing as
    the bloody thing won't run properly now (carb problems methinks). Oh well,
    I think tomorrow will start early for me.
    Oldbloke
    BOTAFOT #140
    Oldbloke, Dec 30, 2003
  15. Oldbloke
    Oldbloke Guest
    Bad form n all that, should have said he successfully completed his CBT
    rather than passed it.
    Oldbloke
    BOTAFOT #140
  16. Take an angle grinder and a lump of metal to work. Problem solved.
    SimonB - South Wales. BOF#32
    email simonb@zapikdotcodotuk
    Triumph Sprint ST,
    ZXR750L2 Wazimbaki.
    Kawasaki Z1R For Sale
    eric the brave, Dec 30, 2003
  17. Oldbloke
    As the only tool that you are allowed these days is a pair of pink
    plastic round-ended scissors, it's probably just as well, really.
    Pip, Dec 30, 2003
  18. Oldbloke
    Getting a badly damaged banger back out on the track for the next race in
    25 minutes - it needs fuel, water, do we have a Renault 4 fan belt? it's
    in the cunting spares box, get the bonnet off twat!, the front sub frame
    needs jacking out, as well as the pedal box and will some fucker change
    the two nearside wheels - is strangely therapeutic.
    Although not usually at the time.
    sweller, Dec 30, 2003
  19. Oldbloke
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    *waves* back.
    I'm going to post you a plywood[1] mockup of the RH hanger tomorrow
    (assuming the necessary tuits are in stock). Check it for the holes
    lining up and the master cylinder fitting where I've put it. I'll
    include a LH hanger as well, just to check it doesn't foul anything.
    Assuming it all works volume production can begin.
    [1] I don't want to waste that much aluminium if it's wrong. It starts
    out as a big chunk of metal, the mill eats all the bits that don't look
    like a hanger and I end up with a small hanger and a big pile of
    swarf...
  20. Oldbloke
    Nigel Eaton Guest
    What shape are they?
    Nigel Eaton, Dec 31, 2003
