Fender Extender
Discussion in 'UK Motorcycles' started by curium, Nov 21, 2003.
  1. curium
    curium Guest
    I have a Fender Extender purchased from the NEC. It comes with 4
    self-tapping screw but I am reluctant to screw it on in case the original
    fender cracks.
    Can anyone recommend a type of glue that will be effective at gluing 2 bits
    of plastic together and is waterproof/weather-proof?
  2. curium
    The fender will crack if you try putting the screws straight in.
    Drill holes in the fender first - put insulation tape over the the drilling
    points to stop the drill slipping
    I did this on my TDM850 - worked a treat. Only needed 2 screws.
    wessie, Nov 21, 2003
  3. curium
    mb Guest
    And while drilling the holes, do not put your finger behind it to support
    the mudguard...
    mb, Nov 21, 2003
  4. curium
    Petel Guest
    Petel, Nov 21, 2003
  5. curium
    Alternatively use a soldering iron to melt in the holes with no chance of
    cracking.
    Hog, Nov 21, 2003
  6. curium
    Verdigris Guest
    On Fri, 21 Nov 2003 20:04:14 +0000, curium wrote:
    No glue will hold them together: the constant vibration will have them
    falling apart in a week or two.
    Verdigris, Nov 22, 2003
  7. curium
    Though this J&B Autoweld is bloody good stuff!
    Hog, Nov 22, 2003
  8. curium
    I'm waiting for curium to ask about the little strip of double-sided
    tape that always comes with them - the one that is good for holding it
    together while you drill the holes, like ;-)
    Pip, Nov 22, 2003
  9. curium
    JohnH Guest
    I used araldite glue on the fender extender for the fazer, works a treat
    and no probs. Have to roughen both contact sides first.
    JohnH, Nov 22, 2003
  10. curium
    Owen Guest
    Cable-ties...YKIMS.....
    O
    1 Black, shortly to undergo extensive surgery.
    1 Red, undergoing lightweight surgery. -----
    1 Blue, for Power-Ranger baiting. | o |
    Numbers ... | o |
    Stuff ... | ooo |
    Life ... -----
    Owen, Nov 24, 2003
