Fekin speedo stopped workin!
Discussion in 'UK Motorcycles' started by steve auvache, Oct 18, 2004.
  1. Robbo wrote
    Depends dunnit.
    Presumably you have actually checked the bits before the speedo are
    *actually* whizzing round in an appropriate manner?
    If this is the case then do as others have recommended.
  2. steve auvache
    Robbo Guest
    Trundling down the M1 yesterday just before the Leicester exit the speedo
    suddenly drops to zero and no mileage recorded on from that.
    Now even *I* know I was moving!
    So, investigation of cable this a.m shows it's intact. It had a new drive at
    the wheel end about 6 months ago apparently.
    So what next speedo head ?
    Robbo
    Trophy 1200 1998
    BMW K100 RS 1984
    B.O.S.M 2003, 2004
    FURSWB#1 KotL..YTC449
    PM#7
    Robbo, Oct 18, 2004
  3. Attach drill to wheel end of speedo cable to test...
    mike. buckley, Oct 18, 2004
  4. steve auvache
    Front wheel off the ground?
    I take it you've found the HBoL inside the topbox?
    platypus, Oct 18, 2004
  5. steve auvache
    PeterT Guest
    Robbo
    New drive at the wheel could still be at fault. On the Transalp
    I've gone through a couple of those as on cog tends to shred the
    other to pieces if there's a bit of dirt hanging around.
    PeterT, Oct 18, 2004
  6. steve auvache
    Robbo Guest
    Yes thanks on the HBoL
    Must admit to *not* being a wheelie style person, so discounted that one.
    Had a look at the drive at the wheel while at work and found the drive
    spigot that comes out is seized. Now as this was fitted in June I suspect it
    will be replaced under warranty so to speak.
    Robbo
    Trophy 1200 1998
    BMW K100 RS 1984
    B.O.S.M 2003, 2004
    PM#7
    Robbo, Oct 18, 2004
  7. steve auvache
    Deadpan. Like it.
    Good luck.
