Fecking Italian electrics
Discussion in 'UK Motorcycles' started by TMack, Apr 6, 2010.
  1. TMack
    TMack Guest
    I took the ST3 for its MOT today. After yesterday's problem with my hip it
    was a struggle getting on and off it but as the MOT was booked I was
    prepared to suffer a bit in order to get it done. It flew through - except
    for the front brake switch which didn't work. Fecking Italian electrics -
    the bastard was working yesterday! The switch seemed OK so ... back home,
    and three allen bolts later I could get at the two bullet connectors that
    connect the switch wires. Disconnected them then reconnected and it now
    works fine again. I cleaned them up anyway to be on the safe side. I will
    now have to wait until Thursday before I can take it in again as I can't get
    away from work tomorrow.
    TMack, Apr 6, 2010
  2. Get a new switch. It failed on my SS last year - corrosion and suchlike.
    Cleaning it up helped for a while, but replacement is yer best bet.
    The Older Gentleman, Apr 6, 2010
  3. TMack
    TMack Guest
    It was definitely the bullet connectors. Its working 100% now. I may
    acquire a new switch just in case but I want to find one at less than the
    £25 or so that ST switches cost from retail sources. Not that I can't
    afford it but I resent the approximately £23 mark-up.
    http://www.wemoto.com/bikes/Ducati/ST3_Non_ABS_992cc/04-07/picture/Brake_Light_Switch_-_Front/
    TMack, Apr 6, 2010
