After you've spent an hour in the midday sun taking the whole top half of the bike apart to get to the back of the clocks, and put it all back together. Then found some pliars, wrapped them in a glove and actually got the bottom end of the speedo drive out of the wheel hub, a 3 minute job at best, I imagine that the following is not to be expected: The ability to pull the last two inches of speedo cable inner out of the outer revealing a slightly chewed looking end. I just wanted to ask because I'm utterly clueless about speedo drive mechanics, but I assume that cable from end to end is supposed to be one continuous unit, right? At least it's not a costly fix if I'm right. Ta.
