Fark
Discussion in 'Classic Motorbikes' started by Dan L, Aug 29, 2007.
  1. Dan L
    Dan L Guest
    Dan L, Aug 29, 2007
  2. now that's a bit on the wet side. I feel sorry for people whose pride and
    joy got ruined, though. some of them with fancy trucks and trailers can
    presumably afford it.
    Austin Shackles, Aug 29, 2007
  3. Dan L
    A.Clews Guest
    Thus spake Austin Shackles () unto the assembled multitudes:
    Would the bikes be write-offs? I would imagine the machinery didn't do
    too badly, but presumably the electr[on]ics would have been FUBAR and
    expensive to replace.
    A.Clews, Aug 29, 2007
  4. Dan L
    If a bike of mine was submerged in mud, and there was no insurance
    involvement, I'd hose it off thoroughly, dry it thoroughly, change the
    fluids and expect it to work. Insurance considerations may complicate
    things.
    platypus, Aug 29, 2007
  5. Dan L
    A.Clews Guest
    Thus spake platypus () unto the assembled multitudes:
    What I should have said was "would the bikes be beyond economic repair" - I
    wasn't actually thinking of insurance when I wrote that first sentence
    admittedly rather clumsily.
    None of the bikes I've owned have ever been submerged so I can't speak from
    experience, but I'd be surprised if the electronics on modern machines
    would survive it unless they're designed to (e.g. sealed gizmo boxes etc).
    Normal electrics are a different matter and would just need drying out,
    presumably.
    I don't propose to test this hypothesis :)
  6. Dan L
    TOG Guest
    Paging Champ!
    TOG, Aug 29, 2007
  7. Dan L
    Unless there's corrosion, I can't see how electronics would be damaged by
    immersion.
    I've flown a light aircraft that had previously been under the Irish Sea -
    little more had been done to it than pouring the water out and drying out
    the upholstery.
  8. Dan L
    crn Guest
    Back when I were a lad I ended up fishing my Bantam and a scrote out of the
    canal. The Bantam recovered after removing the plug and kicking it over
    a few times. The scrote took longer to recover from his kicking over ....
    crn, Aug 29, 2007
  9. Dan L
    Do you know, I don't believe you.
    sweller, Aug 29, 2007
  10. About the scrote? No, nor I.
    About the Bantam - oh yes. I've submerged a Honda XL100 trail bike, and
    I mean completely submerged, in a river, and we got it going within
    20-30 minutes.
    The Older Gentleman, Aug 29, 2007
  11. Dan L
    Nick Guest
    I think a bantam is a two stroke? (I've no idea about old Brit stuff.)
    If so they don't tend to break when they ingest water as readily as 4T
    - the water goes into the crank case instead of the cylinder. I speak
    from experience of submerging both kinds of outboard.
    Cheers
    Nick
    Nick, Aug 31, 2007
  12. Dan L
    You're right the Bantam was a two stroke (based on a DKW/MZ design) but I
    was referring more to the kicking of a scrote as being in doubt.
    sweller, Aug 31, 2007
  13. Dan L
    Those were turbo engines, yeah?
    platypus, Aug 31, 2007
  14. Dan L
    Turbine, ityf. And 6WD.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    '02 MV Senna '03 Tigtona 955i '96 Tiger '79 Fantic Hiro 250
    Krusty, Aug 31, 2007
  15. Dan L
    Wasn't there a Leyland Highlander model with a supercharged Stirling engine?
  16. Dan L
    There can only be one.
  17. Dan L
    "Highlander" was a name used for the prototype of what eventually became the
    Discovery, a shed only distinguished by being named after two fine Pet Shop
    Boys albums.
