Farewell DT175MX
Discussion in 'UK Motorcycles' started by The Older Gentleman, Jun 30, 2005.
  1. Now in the hands of Ivan, along with the gasket set I bought when I
    thought I'd keep it.
    Ho hum. I'll keep looking, but I'll never find another one like it.
    Oh, and Ivan, bless him, arrived an hour and a half late, apologising
    profusely because he'd lost my address and phone number and had managed
    to find me using..... I dunno. Some widget.
    And then he went out on the test ride, and 15 minutes later, thinking
    he'd run out of petrol, I started scouring the streets on my Trophy.
    "The roads round here are hardly orthogonal," quoth he on return. The
    finest excuse for: "I got lost" that I've ever heard.
    I suggested he needed a SKOGA number.
    "I've already got one," he replied. Why am I not surprised? Bless.
  2. Danke TOG. Just made it home, having filled up with £3.12 worth
    of unleaded at your nearest BP. Strangely enough, the oil light came on
    as I got to Stockley Park, but went off again when I stopped at home.
    It was a bit of a woeful tale. There just happens to be an express
    bus, the X26, from Heathrow to East Croydon, stopping at Sutton. It runs
    roughly hourly, and the scheduled departures include 1545, 1645, and 1750.
    Given the rush hour, I gave myself more than an hour to get to Heathrow;
    we got there at 1740 and I walked over to Stop 20 -- just in time to see
    the X26 pull out while I was still 25 yards away!
    I waited until 1800 in case there really was going to be a 1750
    bus, but no show. Took the Picc into Earl's Court and found the District
    Line platform for Wimbledon. Train times were given as every 4-6 minutes.
    Are they bollox! Finally one came along and we trundled off to Wimbledon.
    There was a train to Sutton at 1919; I was unsure of whether my
    Oyster was valid on the train so I doubled back to the Tube platform to
    check a sign, but it was about Tramlink. Back to Platform 9 at exactly
    1919 and no sign of the Sutton train, it had already left.
    Checked out of the station looking for a phone box, reached into
    my pocket for a printout of TOG's message with his phone number -- and it
    had gone AWOL at some stage of pulling out my PDA, Oyster Card, etc, etc.
    :-( Found out that I couldn't use my PrePay for the train, so bought a 90p
    cheap-day single to Sutton and waited for the 1946. Then it started
    bucketing down rain... I thought briefly of trying to find a WiFi hotspot
    to log onto my Brunel account, but my PDA's wireless card was in my other
    rucksack.
    Finally got to Sutton and walked out of the station into light
    drizzle. Now, I wasn't totally unprepared; although I hadn't stored TOG's
    phone number, I *had* programmed his coordinates into my navigation
    programme. So, with six or seven GPS satellites showing me the way, I
    tottered the reasonably short distance to his door, although his house
    number is well-enough hidden to make it a bit hard to verify the house.
    Of course, I also got lost going "round the block" on the test-ride.
    Difficult to judge where I was in the gathering gloom, so out with the GPS
    again (with a momentary glitch that necessitated resetting the whole PDA)
    and I guided myself back by stopping every couple of hundred yards to
    check the instructions.
    The trip home started out OK, following signs to Kingston as
    a first bet. Then it said "For Kingston follow Epsom" so I did that
    for a while, then a sign said "Kingston, Heathrow" and I soon found myself
    on the A3. I realised that this probably wasn't the road I wanted when
    the signs started saying "Guildford, Portsmouth", but it was the M25 soon
    enough, so I followed that around to the Heathrow exit then jumped the A408
    exit to Yiewsley and home.
    SKOGA? I've already got one, for getting lost finding Aylesbury
    for the start of a BOTAFOT run...
    Brunel University. Room 40-1-B12, CERN
    GSX600F, RG250WD, DT175MX. "You Porsche. Me pass!" DoD #484 JKLO# 003, 005
    Dr Ivan D. Reid, Jun 30, 2005
  3. The Older Gentleman
    raden Guest
    And he's trying to track down the Higgs boson ?
    raden, Jun 30, 2005
  4. The oil light comes on in synch with the neutral light. Gawd knows why.
    The Older Gentleman, Jul 1, 2005
  5. The Older Gentleman
    jOn Guest
    old way of checking the bulb still works
    jOn, Jul 1, 2005
  6. Yes, the principle is simple, sound, and often annoying! :)
    But I can assure you I didn't ride from Stockley Park to Cowley Village
    in neutral...
    On that point, has anyone any specific recommendations for 2T oil
    for the air-cooled beastie? Anything to seek out or, more usefully, to
    avoid? We used to swear by Bel-Ray synthetic when I was racing, and I
    believe Silkolene had a bad rep at one stage.
    GSX600F, RG250WD, DT175MX "You Porsche. Me pass!" DoD #484 JKLO# 003, 005
    Dr Ivan D. Reid, Jul 1, 2005
  7. The Older Gentleman
    TOG Guest
    In my experience, Yamaha 2-stroke oil warning lights always come on
    nice and early, and you have to be a total numpty to run the things out
    of lube. IIRC, my 350YPVS light came on when there was still over 150
    miles' worth of oil in the tank.
    Lozzo will be along shortly ;-)
    Oil - and decent semi-synthetic or fully synth (if you're flush) will
    do. I always use(d) Silkolene.
    TOG, Jul 1, 2005
  8. The Older Gentleman
    TOG@toil says...
    Wot 'e said.
    Lozzo, Jul 1, 2005
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    Are there any "do not mix!" cautions with 2-stroke oil types? Or can I
    just bung any old stuff in with whatever Dodger's been using in the TS?
    And does anyone know what tyre pressures seem likely?
    Oh, and memo to self: Do not start the TS when the exhaust is pointing
    at the Shagwah. Still, it needed cleaning anyway...
    and Ducati Race Engineer.
    Enfield 500 Curry House Racer "The Basmati Rice Burner",
    Suzuki TS250 "The Africa Single"
    Wicked Uncle Nigel, Jul 1, 2005
  10. The Older Gentleman
    Salad Dodger Guest
    It had Castrol TT or 2T or whatever. I dunno what Jayne had been
    putting in before me, but I think it was the same.
    Mid twenties, from memory. Try one of the Haynes manuals.
    hehehe - could be worse - you could have started the KH.
    Salad Dodger, Jul 1, 2005
  11. The Older Gentleman
    Salad Dodger says...
    In that case I'd go for a semi-synth and be done with that. I ran my
    strokers on a decent quality semi-synth 2-stroke oil and they only ever
    blew up because I abused them beyond their design spec.
    Lozzo, Jul 1, 2005
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, Salad Dodger
    I am obliged.
    Oddly, neither of them seems to have any mention of tyre pressures at
    all.
  13. The Older Gentleman
    Salad Dodger Guest
    Bridgestone quote 1.8 and 2.0 bar for the trail wing as fitted to a
    TS250ER
