Failed CDI Unit
Discussion in 'Australian Motorcycles' started by Adam, Jun 24, 2005.
  1. Adam
    Adam Guest
    Hi All,
    I own a '99 cbr900 whose cdi unit appears to be stuffed.
    The bike wont start and the spark seems very weak across all cylinders.
    What can cause these units to fail. Before I got to the expense of
    replacing such an expensive item, I want to be sure their isnt another
    underlying problem that has caused the unit to break.
    Thanks,
    Adam
    Adam, Jun 24, 2005
  2. Did you tour on it?
    Hammo
    Hamish Alker-Jones, Jun 24, 2005
  3. Monkey says "boo hoo hoo".
    Hammo
  4. Adam
    David Guest
    dog ... bone ...
    David, Jun 24, 2005
  5. I would maybe check somehere else 1st. Usully when the CDI unit fails it
    fails completely.
    Grab a multimeter and a Service Manual it will tell you have to check the
    CDI unit.
    Zaphod Beeblebrox, Jun 24, 2005
  6. yer...wot he said
    multimeter, manual
    check um pickup coils, wiring, ignition coils themselves, volts,
    amps...but if its the CDI box its probably borked
    what causes them to blow...being used an stuff
    fulliautomatix, Jun 24, 2005
  7. FUCKWIT!!
    It's harsh week you know.
    Hammo
    Hamish Alker-Jones, Jun 25, 2005
  8. Depending on the unit, it may need to be load tested, or you'll get
    erroneous results.
    Mind you, there isn't much room for luggage, so it can't be a tourer.
    Hammo
  9. Adam
    G-S Guest
    Hammo toured on his Z1300... it caused almost exactly the same problem
    as you have!
    G-S
    G-S, Jun 25, 2005
  10. Adam
    sharkey Guest
    Before replacing the "mysterious black box":
    a) clean all connectors with electrical contact cleaner.
    b) disconnect kill switch wire at the CDI and see if problem
    goes away. Sometimes it's just a leak in that
    circuit.
    c) make sure whatever feeds it power is working (are there
    seperate CDI exciter windings on the generator? Are
    they producing the specified voltage/resistance?)
    It's suspicious that it's across all cylinders, because the thingummy
    which usually seems to go is in the output stage.
    -----sharks
    sharkey, Jun 25, 2005
  11. Hammo also has spare CDIs. They are probably worth more than his bike!
    Hammo
    Hamish Alker-Jones, Jun 26, 2005
  12. As has been said, bit sus cause usually when the CDI goes you don't get
    anything (although I had a CDI get fried on my KR1 which gave an
    erratic spark and some impressive backfiring). Betta Bikes in SA (look
    em up, they're in the phonebook and online) can test and repair CDIs
    and would be worth talking to given the price of a new unit.
    lemmiwinks.au, Jun 27, 2005
  13. Adam
    Guest Guest
    Ditto Small Coil Rewinds in Geelong
    Guest, Jun 27, 2005
