F.O.A.K: To SP2 or not to SP2
Discussion in 'UK Motorcycles' started by tallbloke, Oct 20, 2004.
  1. tallbloke
    tallbloke Guest
    I've heard a couple of reportsof things going badly wrong upon installing SP2
    on win xp pro in networked environments.
    Any anecdotes or informed opinions?
  2. tallbloke
    Big Tony Guest
    And there was me thinking you were going to trade in the Matchless for
    Honda's fine V twin.
    Big Tony, Oct 21, 2004
  3. tallbloke
    tallbloke Guest
    If I was looking for a v twin it'd more likely be an ST2
    tallbloke, Oct 21, 2004
  4. tallbloke
    tallbloke Guest
    What was broke this time? :)
  5. tallbloke
    John Higgins Guest
    Personal experience - 5PCs - 0 problems.
    Dell Dimensions, Dell Inspiron and a homebrew.
    John Higgins, Oct 21, 2004
  6. tallbloke
    muddycat Guest
    What wasn't?
    muddycat, Oct 21, 2004
  7. tallbloke
    Catman Guest
    Apart from the crappy firewall, no issues with either my own PC, or those
    of my clients that have been upgraded.
    OTOH a friend who writes bespoke software has had some issues with popups
    and so on.
    www.cuore-sportivo.co.uk
    Catman, Oct 21, 2004
  8. tallbloke
    Dr Zoidberg Guest
    I've had one machine that reboots constantly because of ACPI issues with the
    BIOS , another that claimed to be working fine but would no longer support
    the network card , and about 30 that all worked fine.
    Neither of the problem machines required a re-install of windows as SP2
    could be removed on the one , and the NIC card swapped on the other
    Alex
    YZF 600
    "I laugh in the face of danger"
    "Then I hide until it goes away"
    www.upce.org.uk
    www.drzoidberg.co.uk
    Dr Zoidberg, Oct 21, 2004
  9. tallbloke
    Gyp Guest
    Generally it seems OK, however there is a theme problem that causes
    problems for Turnpike - at the moment I have to run in "classic" theme
    until the fix appears. I also have some problems with my Hauppauge
    WinTV.
    Nothing annoying enough to make me move back as yet.
    It can sometimes be fun trying to get pop-ups that you want these days,
    as I think I've got about 5 or 6 apps busily blocking one after the
    other.
    Gyp, Oct 21, 2004
  10. tallbloke
    Dan White Guest
    Both running XP Pro:
    Desktop PC - No problems
    Dell inspiron Laptop: Fucking nightmare. Right-clicking any file caused
    explorer to lock up, then the Dr Watson debugger itself locked up. End up
    having to kill explorer and the debugger in Task Manager, then restart
    explorer.
    When the time comes to do a format/reinstall on the laptop[1], I'll try
    putting it on at install time, before anything else. It'll probably be ok
    then.
    [1] Typically about once a year, usually has a nice effect on performance.
    Dan White, Oct 21, 2004
  11. tallbloke
    tallbloke Guest
    Of XP SPII
    Hmmm. I think I'll go with this.
  12. tallbloke
    tallbloke Guest
    Fairy nuff.
    Why not just use one which does the job properly?
  13. tallbloke
    tallbloke Guest
    Bill knows best, you should be aware of that.
  14. tallbloke
    gazzafield Guest
    It's an annoying piece of crap. If you know your way around computers it
    will just bug the hell out of you. Windows in nag mode. It's so bad, have
    to use it in work you see, that after having only played around with Linux I
    am now a big fan of Fedora Core 3 and use it almost exclusively at home.
    It's good for newbies and those who don't want to get too technical and I
    advise them to go for it every time.
    gazzafield, Oct 21, 2004
  15. tallbloke
    tallbloke Guest
    I'm a convert. I use gnu debian though.
  16. tallbloke
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, gazzafield
    Really? How odd. I installed it, turned the firewall off because I
    already have one, and haven't seen it since. Oh I lie, it asked me if
    I'd let one site run Active-X controls.
    Nigel Eaton, Oct 21, 2004
  17. tallbloke
    tallbloke Guest
    I agree. On all three points.
  18. tallbloke
    tallbloke Guest
    Ah now that's interesting. I haven't tested the throuput pf the usb 2 ports on
    my Tosh M100. Is there a quick and easy test apart from timing the transfer of
    a large file?
  19. tallbloke
    Catman Guest
    Twaddle. Just turn the nags off.
  20. tallbloke
    Cab Guest
    tallbloke bored us all completely to death with wittery prose along the
    lines of:
    I've had no major problems at all on both the work PC and the home PC.
    The only nag I do have, is that when I do a hotfix update that requires
    a reboot, and I say "no, do it later", the system does the reboot
    automatically later on, if you're not actively using the system (as in
    physical actions). It doesn't appear to give a shit about the fact that
    I have running apps doing file conversions, etc.
    Cab, Oct 21, 2004
