Extra Lights
Discussion in 'UK Motorcycles' started by Cane, Dec 9, 2003.
  1. Xref: intern1.nntp.aus1.giganews.com uk.rec.motorcycles:1464710
    flash !!
    1st best have a look at http://www.ukrm.net/faq/ukrmscbt.html
    especially the bits on snipping.
    It's already been mentioned ^^^ in the thread that the lights should
    be wired in with the existing lights, I am not 100% sure on this but
    http://www.piaa.co.uk/pricelist/glossary.htm seems to agree.
    <FX waits for SWK>
    Ian
    "reorganising, a wonderful method for creating an illusion of
    progress"
    znvygb: (ROT13 all of it to mail me)
    The FAQ is here http://www.ukrm.net/faq/index.html
    98 FZS600, 72 T120R two#34 MIB#21 TWA#6
    Boots Blakeley, Dec 9, 2003
  2. Cane
    Well yes but otherwise also *if* the beam has a proper cut-off as per a dip
    beam. I guess you can have as many "proper" headlights as you want?
    Hog, Dec 9, 2003
  3. Cane
    Ben Blaney Guest
    I thought it was a joke, that would link to a page saying "**** off
    then". I was very disappointed.
    Ben Blaney, Dec 9, 2003
  4. Cane
    It is something of an anti-climax. A red screen with green text plus audio
    screaming *get a life you ***** would be nicer. Anyone care to hack it?
    Hog, Dec 9, 2003
  5. Cane
    BTW I was in an auto shop yesterday buying some driving lights for a cage
    and saw something that could be nice on a bike. Set of two small black shell
    spotlights with angel eye LED sidelights on the circumference in a BMW 5-ser
    fashion <thinks Gixxer>
    Hog, Dec 9, 2003
  6. Cane
    Brian Guest
    Thanks guys, some usefull stuff - Like the Autoswitch Mike.
    tried to snip this time - sorry if it fails....
    Brian
    Brian, Dec 9, 2003
  7. In uk.rec.motorcycles, Ben Blaney said:
    Me too. I lost my connection before the page loaded.
    Whinging Courier, Dec 9, 2003
  8. Cane
    Alan.T.Gower Guest
    ITYM "Y fronts"
    Alan
    http://www.ads-training.co.uk
    "Kneesliders Sponsored by Cane"
    GSX-R1000 , Triumph Thunderbird, ZXR750L2 Racer(gone), GS500,
    GHPOTHUF#27
    TGF, UKRMFBC#7, Two#24, BOTAFOF#11, YTC#9, GYASB#1. SbS#23.
    DFWAG#2, DS#2, DIAABTCOD#20. remove "thisbit" in the reply
    http://sportsbike.org (our own endurance team) http://Team-ukrm.com
    "Nemo repente fuit turpissimus"
    Alan.T.Gower, Dec 9, 2003
  9. Cane
    Alan.T.Gower Guest
    Legal provided they're aligned properly and wired to work with main beam
    only.
    I had them on my Harley but the MOT station said that they couldn't MOT
    it because they weren't sure. To save any argument I simply disconnected
    them for the MOT.
    Alan
    GHPOTHUF#27
  10. Cane
    K Olley Guest
    Seconded, when fitting just take the switched side of the relay to the
    main beam supply via a switch, same laws apply regards fitment to cars
    or bikes.
    You need one like mine, he could MOT a modern sports bike but he would
    be just as familliar with one fitted with the original old style
    acetylene lamps:)
    Kevin - Basildon
    XV535
    GPZ305 (her's)
    BOTAFOT#67 BOTAFOF#23
    OSOS#29
    K Olley, Dec 9, 2003
  11. And, if you're mounting them as headlamps only (ie, in place of a normal
    headlamp) you mustn't have them too far apart in case you might be
    mistaken for a car.
    Having them too far apart might be a problem if your main light packs up
    and you have to use them as your sole illumination - you'd appear to be
    a car some distance away, when in fact you're only 50 yards off and some
    fucker might pull out in front of you.
    GS 850 x2 / SE 6a
    SbS#6 DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Dec 9, 2003
  12. Cane
    flashgorman Guest
    Damn. Should have said "So they couldn't pin anything on you then?".
    flashgorman, Dec 9, 2003
  13. Cane
    You mean Fog Lights
    Hog, Dec 9, 2003
  14. Cane
    Rope said....
    Couldn't he find a car to nick instead?
    Lozzo, Dec 9, 2003
  15. Cane
    That will be a relief to all concerned, I would imagine. Indoctrinate
    him now, while you have a chance.
    Pip, Dec 10, 2003
  16. Cane
    sweller, Dec 10, 2003
  17. Cane
    <obvious mode>
    people, glass houses, stones
    Hog, Dec 10, 2003
  18. Cane
    deadmail Guest
    heh. I broke my leg once whilst 'going commando'.
    They'd worked out it was broken without removing my jeans (I was quite
    insistent).
    Then they had to plaster it... so the jeans had to come off. I found it
    embarrassing...
    "Look, it's only that small because I'm in shock, OK?"
    deadmail, Dec 13, 2003
