Exhausts and MOT's
Discussion in 'UK Motorcycles' started by rufty_tufty_hoolythug, Jul 7, 2009.
  1. Do exhausts need to be BS stamped to pass your MOT? Or is it that
    they must not leak too much and not be excessively loud?
  2. rufty_tufty_hoolythug
    Don't have to be BS or E stamped, but mustn't be stamped 'off road use
    only' or 'race use only' or anything like that (but if they are,
    aluminium tape is your friend). Regardless of markings, they mustn't be
    louder than what the tester would expect for the type of bike.
    Krusty, Jul 7, 2009
  3. rufty_tufty_hoolythug
    ginge Guest
    Or a dremel, with a polishing disc, which is what I've used on a
    couple of cans now.
    ginge, Jul 7, 2009
  4. rufty_tufty_hoolythug
    In that case I shouldn't have a problem getting the Hardley MOT'd :).
    Timo Geusch, Jul 7, 2009
  5. rufty_tufty_hoolythug
    zymurgy Guest
    The "not for road use" markings on the Triumph competition can are
    about 2" square. It needed a "large" bit of aluminium tape.
    If you rub at the tape, you'll be able to read the mark, so i'm not
    sure that it's a good idea to MOT it with them on. The PITA is that I
    have to remove the Givi pannier racks to get the Exhaust off.
    Thanks Givi, you bunch of cunts.
    Paul.
    zymurgy, Jul 7, 2009
  6. rufty_tufty_hoolythug
    TOG@Toil Guest
    Heh. Who here remembers the model of 'silencer' made by Dunstall,
    aptly called the 'Decibel'? I had two of them on my first XS650, and
    thy prompted a friend to call it "a real lout's bike".
    TOG@Toil, Jul 7, 2009
  7. rufty_tufty_hoolythug
    Or a tester who supplies a roll of black insulating tape, looks at the
    result and advises another layer as the engraving is still visible.
    Pip, Jul 7, 2009
  8. rufty_tufty_hoolythug
    petrolcan Guest
    There was a pair on the Z400 you sold me.
    petrolcan, Jul 7, 2009
  9. rufty_tufty_hoolythug
    Eddie Guest
    I thought you'd never had a loud aftermarket exhaust.
    Eddie, Jul 7, 2009
  10. rufty_tufty_hoolythug
    boots Guest
    I had them on my 750 bonneville, silencer was somewhat of a misnomer.
    boots, Jul 7, 2009
  11. rufty_tufty_hoolythug
    Pete Fisher Guest
    I see you can still get 'Megaton' 'silencers'.
    | Pete Fisher at Home: |
    Pete Fisher, Jul 7, 2009
    The Older Gentleman, Jul 7, 2009
  13. rufty_tufty_hoolythug
    They were great but when they rotted a bit and shot out as if they
    were guided missiles they damaged the garden shed and your parents got
    a bit moody about it. Allegedly.
    Reverse cone megas were the real hooligans friend on an XS650 but they
    tended to deck a bit easily and the aluminium cones needed to be
    removed and turned around to stop them ripping off completely.
    Allegedly.
    Andy Bonwick, Jul 7, 2009
  14. rufty_tufty_hoolythug
    Mike Barnard Guest
    I'm old enough to have played there too, but I preferred those BSA
    copies that 'whistled' at idle. What were they called... were they
    "Gold Stars" or summat? I had them on an ex police T160P back in the
    '70's. I wonder where that is now?
    Mike Barnard, Jul 7, 2009
  15. rufty_tufty_hoolythug
    Eddie Guest
    Oh, right.
    Nah, I'll believe you this time.
    Eddie, Jul 8, 2009
  16. rufty_tufty_hoolythug
    zymurgy Guest
    Sometimes, though not often, I hate you.
    Paul.
    zymurgy, Jul 8, 2009
  17. rufty_tufty_hoolythug
    Eddie Guest
    I think I've said this before: our tester was advised by his doctor to
    take life easy, relax, not to get too much excitement. So he watches his
    porn with one eye shut, and takes the same approach to doing MOTs.
    Eddie, Jul 8, 2009
  18. rufty_tufty_hoolythug
    Dave Benj Guest
    High level pipes and corrugated cardboard stuffed in your boots cured
    that.
    Allegedly.
    Dave Benj, Jul 8, 2009
  19. rufty_tufty_hoolythug
    Go for it, man. Don't let sympathy get in your way.
    Pip, Jul 9, 2009
  20. rufty_tufty_hoolythug
    I took the "not for road use" markings off the Ti cans I had for the
    TRX using Autosol and a bit of elbow grease.
    darsy, Jul 9, 2009
