exhaust sludge
Discussion in 'Motorcycle Technical Discussion' started by jr, Jul 10, 2005.
  1. jr
    jr Guest
    the clip was on one so so i put it at the second one down i've leaned out
    my main from a 390 to 340 one step down at a time it seemed best at 340 but
    it was surging pretty bad i've done nothing else
    jr, Aug 10, 2005
  2. So tells us what your spark plug insulator looks like when you do a
    "plug chop". Run the engine at full throttle for a mile or so, pull the
    clutch in as you hit the kill button, coast to a stop without idling,
    let the engine cool off so you can pull the spark plug and see what it
    looks like.
    Also, are you over-oiling the air filter? Is there a dead rat in the
    air box, or something restricting airflow to the carb? One guy said he
    had a rodent's nest in the airbox, another guy said he found shop
    towels in there. I personally had a home made air cleaner hose collapse
    on me, and that acted like a choke.
    Then there is that possibility of a bad petal on the reed block
    allowing the carb to suck a double shot of fuel...
    krusty kritter, Aug 10, 2005
  3. jr
    jr Guest
    no and no
    jr, Aug 11, 2005
