Exhaust popping on decelleration...
Discussion in 'Texas Bikers' started by Elequin, Jul 31, 2003.
  1. Elequin
    Elequin Guest
    Okay, admitedly, I'm a green newbie at engines and wrench work.
    Since getting my bike, I've taken a slight interest in doing some
    of the work that it needs myself ($60 an hour? ouch!). I had
    the bike (1980 GS1100L) serviced, and the mechanic said he could
    not do much to adjust the carbs because the boots on them are leaking
    a lot of air. I know I need to get these boots replaced, I just
    need to find the time.
    Okay, now to the question for you gearheads out there. :) Can
    the engine running lean cause the bike to "pop" out the exhaust
    a lot when decelerrating? When I'm going at a good clip and then
    just totally let off the throttle, the exhaust goes pop-pop-poppop-
    pop-poppop... Is this a symptom of running too lean, or do I need
    to look elsewhere?
    Thanks!
    - Eric
  2. Elequin
    Joe C. Guest
    I had the same problem with my Yamaha XS750. I took the carbs off and
    cleaned them really well, changed the plugs, ran super unleaded gas + gas
    treatment through the tank. In the end, I couldn't get rid of the popping
    noise. I found it is easier to tell people that you adjusted it that way on
    purpose because it sounds cool. :)
    Joe
    Joe C., Jul 31, 2003
  3. Elequin
    Charles Soto Guest
    The air getting in past the boots is responsible for the pop. Replace
    the boots.
    Charles
    Charles Soto, Jul 31, 2003
  4. Elequin
    Brian Walker Guest
    When you figure it out, could you let the rest of us know? There have
    been plenty of people trying to get their motorcycles to make those
    sounds, and their's just run too good and keep idling down like
    they're supposed to.
    Any help with getting a bike to do what yours is doing would be
    appreciated.
    Brian Walker, Aug 1, 2003
  5. Elequin
    !bungle Guest
    The Suzuki Savage 650 Single (all model years) also backfires upon
    deceleration and the common theory is that EPA-mandated carb mixture
    settings (too lean) are the culprit.
    At least your bike doesn't have the mixture adjustment screw plugged with
    brass to avoid owner tampering. I'm going to Dremel mine out when I've got
    some time to kill...
    However, in your situation it could well be the carb boots.
    Dirk
    (aka "!bungle")
    '96 LS650
    (aka "Rhino")
    "Well, you may be a lover but you ain't no d-d-dancer"
    !bungle, Aug 1, 2003
  6. Elequin
    Elequin Guest
    Haha. I'll let you know. :)
    Thanks to everyone for the tips! I'll replace the carb boots as
    soon as possible. If that doesn't fix it, I'll look at adjusting
    the carbs, etc. Now I just have to find the time. ;-)
    - Eric, destined for an auto shop for radiator hose in the near
    future to replace the carb boots. heh
    Elequin, Aug 1, 2003
  7. Elequin
    curatuk Guest
    87 Honda Rebal, great starter bike, it's been starting for 3 yrs.
    Only have to lean out the carb very 30 miles or less to keep it
    from poppong out the exhaust pipes, and lossing 10 mile an hour.
    curatuk, Aug 2, 2003
  8. Elequin
    fullstate Guest
    I'm not really a mechanic, but it is my understanding that there can
    be a lot of reasons for the popping. The largest concensus is that
    your bike is probably runing a bit lean, I do believe.
    The boots would make a difference, but keep in mind it can be a whole
    bunch of different things.
    In a proper exhaust system there should be some back-pressure through
    the exhaust to the engine. Too little, or too much back pressure can
    cause the valves to not open / close properly and that also can create
    your popping sound, not to mention other various pre/post ignition
    problems.
    Some bikes, do it normaly, though I don't think yours is supposed to
    and is probably indicitive of some other issue.
    fullstate, Aug 2, 2003
