exhaust pipe bends (or lack of)
Discussion in 'Motorbike Technical Discussion' started by Rev. Zack, Dec 8, 2003.
  1. Rev. Zack
    Rev. Zack Guest
    I'm working on a custon and had a question about making an exhaust. Its a
    v-4 and Instead of bending the pipes I was going to cut the pipes at 45's
    and weld it together. I know it will disrupt exhaust flow, but wouldnt it
    also allow me to not run baffles because it would give a little
    backpressure?
    Rev. Zack
  2. I'd think that it would disrupt the exhaust a lot, but it won't do as
    much to cut the noise. Hooker (among others) sells some bent pieces
    that are intended to be cut up and welded into headers. They're not
    terribly expensive either.
    Matthew Lundberg, Dec 8, 2003
  3. Rev. Zack
    Greg Guest
    Why don't you put baffles in anyway and make the world a little be nicer place?
    Greg
    Greg, Dec 8, 2003
  4. Rev. Zack
    Tony Page Guest
    Dont forget to get your carbs retuned after....
    Tony Page, Jan 8, 2004
