Exhaust Info Required
Discussion in 'UK Motorcycles' started by David Thomas, Oct 18, 2003.
  1. David Thomas
    David Thomas Guest
    Hi All
    Wonder if anyone can enlighten me, I have bought a 1996 Suzuki Bandit 600N
    and it has a carbon silencer fitted, I have also been given the original
    Suzuki stainless silencer with the bike.
    So, I was wondering why people fit non-standard exhausts, is it purely for
    the sound or does it increase performance and should the bike be tuned to
    suit a non-standard exhaust.
    Don't get me wrong it sounds lovely with the carbon one, was just wondering
    if it was detrimental to the engine fitting these ?
    Regards, David
  2. David Thomas
    You will find that the (carbon) replacement exhaust is considerably
    lighter, probably much more free-flowing and almost inevitably noisier
    than the standard can. This means that there is less resistance to
    the engine when trying to get rid of exhaust gases, which (up to a
    point) is a Good Thing.
    The additional noise is largely a matter of personal taste, but there
    is a considerable body of (largely anecdotal) evidence to show that
    Loud Pipes Save Lives. In the urban environment, pedestrians can hear
    you coming, even if they don't see you (or even look ;-)) and are so
    less likely to step off the pavement under your front wheel. When
    filtering in or out of town, car drivers can hear you coming and are
    more likely to look in their mirrors and spot you - sometimes they'll
    even move out of your way. Better for you, better for them. A
    win-win situation, and you don't see many of them, do you?
    My SO replaced the original can on her CBR600FS with an Akrapovic
    item. Her father disapproved gently (he being a motor engineer of
    many years experience) and could not understand why she wanted to fit
    it.
    After a few weeks, we could draw the following conclusions: the
    Akrapovic flows much better, giving an improved throttle response and
    making the power delivery much smoother(1); there are no signs of
    fuelling problems; the fuel consumption has _improved_ by at least 20%
    overall.
    Additionally, it looks better, is about 20% of the original's weight
    and it sounds sublime, yielding a deep and fruity "thrum" which is
    much more pleasant than the (not unpleasant) original.
    Dad is convinced, which is well good enough for me.
    What you want to do, once you are accustomed to how the bike sounds
    and feels, is swap back to the original. Check the differences for a
    week or so, then swap back. Then you can take your pick on a much
    better informed basis.
    1. Taking the "emissions test dip" around 5K rpm out almost
    completely.
    HTH.
    Pip, Oct 18, 2003
  3. David Thomas
    David Thomas Guest
    Many thanks for the information particularly your comments about the exhaust
    volume making other road users aware of you presence... seems to make good
    sense.
    Regards, David
  4. David Thomas
    Steve H Guest
    After replacing the original boat anchor fitted as the standard exhaust by
    Aprilia on my RSV and replacing it with an Akrapovic slip on, I've also had
    a significant improvement in fuel consumption, plus a similar 'filling in'
    of the dip at 5000 rpm.
    Since then I'v gone up 2 teeth on the rear sprocket (gearbox sprocket
    already down to 16 teeth from the original 17) which has gone some way to
    reducing the mpg but at least it sounds nice!
    Steve Ho
    Steve H, Oct 18, 2003
  5. Champ wrote
    <Fx: raises eyebrow quizzically>
    steve auvache, Oct 19, 2003
  6. David Thomas
    Salad Dodger Guest
    Bwahahahahahahahahahaha [1] <choke> <thud> <wheeze>
    [1] Spellchecker suggested "electroencephalographic" :-/
    | ___ Salad Dodger
    |/ \ GL1500SEV/CBR1100XXX/KH500A8/TS250C/exTS185C
    _/_____\_ ..61036../..13743.../..3157./.19406/.fecked.
    |_\_____/_| IMC#4 TPPFATUICG#7 YTC#4 DIAABTCOD#9 PM#5
    (>|_|_|<) BOTAFOT #70 two#11 Ignoramus #0001
    |__|_|__| BOTAFOF #09 IbW#0 & KotIbW# OSOS#07
    \ |^| / WG* BotTOS #6 GP#4 ANORAK#17 FTB#14
    \|^|/ 2003 RBR landmarks:99 points:2100 miles:8000
    Salad Dodger, Oct 19, 2003
  7. Salad Dodger wrote
    Mine, rather boorishly I feel, refuses to comment.
  8. LOL...
    SimonB - South Wales. BOF#32
    Triumph Sprint ST,
    ZXR750L2 Wazimbaki.
    Kawasaki Z1R For Sale
    eric the brave, Oct 19, 2003
