exhaust clamp bits
Discussion in 'UK Motorcycles' started by Gyp, Jul 23, 2009.
  1. Gyp
    Gyp Guest
    After some dicking about with the exhaust on the bumblebus, I've had to
    use the angle grinder to seperate some rusty bits.
    The clamp that holds the silencer to the cat is stupid expensive [1]to
    replace, however it's all in good condition except for the
    nut/bolt/spacer thing, similar to:
    http://www.motorworks.co.uk/bmw/prodimages/sm/EXA41478.jpg
    On all the ones I've seen, the bolt head is shaped to match the clamp,
    and is an interference fit into the spacer in the middle. I'm not sure
    that taking one apart would be successful.
    Does anyone know if the nut/bolt/spacer things are available without the
    clamps, preferably in stainless, so I can rebuild my original clamp?
    [1]£70++ with integral heat sheild/trim bollocks
    Gyp, Jul 23, 2009
  2. Gyp
    These any good to cannibalise?
    http://www.busters-accessories.co.uk/productinfo/EXC3740/Exhausts/Exhaus
    t-Brackets-and-Clamps/On-Two-Wheels/430-Grade-S-S-Exhaust-Clamp
    Krusty, Jul 23, 2009
  3. Gyp
    Gyp Guest
    Gyp, Jul 23, 2009
