Exhaust baffles and carbies
Discussion in 'Australian Motorcycles' started by Fat Crack Ho, Dec 14, 2003.
  1. Fat Crack Ho
    Fat Crack Ho Guest
    I've knocked out the exhaust baffles on my bandit 250. Just want to know if I
    can get away with the same main jet or do I need to get a bigger one? Can I
    just richen the needles and leave it at that? The plugs were the righ colour
    before knocking out the baffles. Now they are bone white.
  2. Fat Crack Ho
    Charlie Guest
    the main is the one to be most concerned about, I'd have thought.
    sounds like a richer clip setting and bigger main are called for...
    Charlie
    Charlie, Dec 14, 2003
  3. Fat Crack Ho
    Conehead Guest
    Front sprocket will need to be resized too, don't forget.
    Conehead
    Conehead, Dec 14, 2003
  4. Fat Crack Ho
    Johnnie5 Guest
    dont forget to split the cases
    Johnnie5, Dec 14, 2003
  5. Fat Crack Ho
    RM Guest
    u'll have to make it richer, raise needles all the way and put a 1/8 th
    drill through the main jets.
    seriously though...all that noise and fuss and mucking about for 2 hp
    anyway its done now
    if you can read plugs and pull the carbies apart and have a set of jet
    drills you can go a little bit bigger and test then perform countless
    iterations till it runs right
    or just take it to a dyno tuner
    RM, Dec 15, 2003
