Everything that can go wrong
Discussion in 'UK Motorcycles' started by BGN, Feb 4, 2006.
  1. BGN
    BGN Guest
    That will be be on my grave stone, if they ever find my body, one day.
    I've just spent the last three hours fitting my replacement ER-5
    clocks that I finally found on ebay and while fitting it to the mount
    on the bike the rear of the clocks (the plastic mounting) returned
    back to its natural form. I marched into the back garden, moved a few
    flower pots and parked the ER-5 facing a shed. I am not pleased and
    am pissed off in a number of ways and I don't feel able to put them
    into words at the moment.
    I've put the clocks in a box far, far away from me and have taken the
    now useless mount off of the front of the bike before I do something
    horrid with it.
    <http://www.busters-accessories.co.uk/proddetail.asp?prod=MMSP>
    Is there ANYTHING that could possibly go wrong with sticking the
    speedo cable from the front wheel into this speedo (first one I saw on
    Buster's) on my bike and bolting the speedo where the old clocks used
    to go? Oh, and do you know of any other places that sell a a simple,
    uncomplicated, bland speedo apart from Busters as I don't particularly
    want a small one.
    If it is likely to work then can you clarify if any of the following
    is likely to be an MOT or roadworthyness issue:
    1) No idiot box (no green flashing signals, neutral light, full beam
    light, etc, etc.)
    2) No back-lighting (will not be able to see it at night)
    3) Anything else that I've likely to forgotten
    Thanks for your advice again.
    BGN, Feb 4, 2006
  2. BGN
    BGN said...
    Stop flouncing and stick the box in the post to me. I'll weld it back
    up. Then you can get someone with a clue to help you fit them on the
    bike without destroying them again.
    Lozzo, Feb 4, 2006
  3. BGN
    BGN Guest
    I didn't notice from the photo on the auction that the post-disastered
    clocks had already been bodged together. It looks like someone with
    clues has tried to fix them by melting the brittle plastic on the back
    and 'smudging' it over the crack to form a complete unit.
    I thought this was a good idea until I put any kind of pressure on to
    the three mounting points at which point two of them snapped off while
    I was just tightening them with only one melted mounting point left
    which can't really hold the weight of its friends.
    Do you think re-re-melting brittle and broken plastic will work? If
    yes then I'll throw them in the post next week.
    BGN, Feb 4, 2006
  4. BGN
    dwb Guest
    <note I'm not picking on you>
    I personally really wouldn't think having the above would be a good
    thing - not from a MOT or roadworthyness POV - but from a simple common
    sense POV.
    No idiot lights - how will you know if you've left your indicator stuck
    on? Your main beam? Know you're in neutral? Sure, you can get round
    these, but is it worth it?
    Not being able to read your speedo is also asking for issues if you ask
    me. I'd take Loz up on his offer.
    If it were me, I wouldn't ride it like that. I know others here would
    happily use a pedal bike speedo so, I guess flip wibble do.
    dwb, Feb 4, 2006
  5. BGN wrote
    See lad, learning to live with your motorcycle is a lot like learning to
    live with a beautiful woman....
    steve auvache, Feb 4, 2006
  6. BGN
    BGN Guest
    I just feel that everything I do to that damn bike goes to shit in
    some way. It's not like I've never taken anything apart before (I've
    built computers and things like that in my spare time) but anything
    that has ever had Kawasaki printed on it might as well have burst into
    flames.
    I'm feeling very negative today.
    I've stuck it in the back garden. It's currently in disgrace and I'm
    not going to use it without a speedo.
    BGN, Feb 4, 2006
  7. Perhaps not the best day to tackle something that needed care and
    attention then?
    Are you sure you have this the right way round?
    Dnc
    B1200 - +30bhp ~|~ ZZR1100 - faster when upright
    V2300 - flat cap and rug ~|~ A6 2.5TDi V6 Quattro Sport
    DoetNietComputeren, Feb 4, 2006
  8. BGN
    BGN said...
    I've welded some real nasties so far, and they've held. The clocks on my
    Bandit have been welded for a year or so now and about 8K miles.
    Lozzo, Feb 4, 2006
  9. BGN
    'Hog Guest
    Meantime that little speedo is the same as have on the B12. Works
    perfectly. Spot on up to 70. Roughly right at 120 then it goes bonkers.
    'Course I also have one of the large version of
    www.banditmania.co.uk/digital_clocks.htm
    Unfortunately it's the small one I want to fit. Must get the thing sold.
    'Hog, Feb 4, 2006
  10. BGN
    Muck said...
    Has nobody actually been into a Kawasaki dealership and enquired about
    the cost of a new backing/mounting plate. The GPZ500 clocks are fully
    rebuildable in parts. You can buy new casings, new backplates, new tacho
    and speedo heads and even wiring looms. I am sure the ER-5 ones will be
    the same.
    Lozzo, Feb 4, 2006
  11. BGN
    The idiot lights are easily fixed up with some aluminium plate and a
    visit to Maplins. You can get a generic speedo for a bike, I saw one on
    a ratty Kwak the other week, it worked and had a back light.
    You did the right thing leaving it before the red mist decended.
    Hmm..
    Ok.
    Fair.
    Enough.
    If you want me to do some creative bodging of clocks / lights you are
    welcome to pop round. I think I've got all next week free, but haven't
    had any info as to what a semester 2 introduction week is from the
    university yet..
    Muck, Feb 4, 2006
  12. BGN
    dwb Guest
    I suspect the timing is all wrong ;-)
    dwb, Feb 4, 2006
  13. BGN
    BGN Guest
    You're a gem Loz. I'll post it next week.
    I'm annoyed at myself for this: Everything I touch these days turns to
    shit and I keep being bailed out by UKRMers.
    I'm creating unnecessary Real World work for you lot and am abusing
    friendships and relationships of people that hardly know me. This is
    something that just doesn't happen anywhere else and I don't like
    putting the burden on your shoulders. In short I feel selfish and
    that I'm 'using' you and other good people like Muck, TOG and my
    Wickedest Uncle by getting work done which would normally cost
    hundreds of pounds for nothing - abusing your kind natures. I don't
    like doing it and it's a real cause for concern.
    BGN, Feb 4, 2006
  14. BGN
    BGN said...
    **** off you soft **** and send the fucking clocks pronto, OK?
    Lozzo, Feb 4, 2006
  15. BGN
    Nick, you're a good bloke and a friend. That's what friends are for.
    Besides, you do make the effort, which is more than can be said for
    some[1].
    [1] I once spent ages making a illustrated photo guide to checking the
    valves on a CG125 for someone on here, but what he really wanted was for
    me to do the job coz he was a lazy fucker.[2]
    [2] You're not a lazy fucker.
    Muck, Feb 4, 2006
  16. BGN
    Of course, but why buy new when you can bodge. :)
    Actually, I didn't know you could rebuild Kwak clocks like that. Nice
    one Loz.
    Muck, Feb 4, 2006
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, BGN
    Don't be a ****. It's all swings and roundabouts on here. Sooner or
    later you'll have a chance to help someone out, and you just do it. No
    one keeps score, you just do what you can.
    Wicked Uncle Nigel, Feb 4, 2006
  18. BGN
    BGN Guest
    My nearest Kwak dealership is in Maidstone somewhere. I'll give them
    a call next week. Do you know the name for the big white plastic bit?
    <grabs replacement clocks and camera>
    *snap*
    <http://hayn.gotadsl.co.uk/bike/clocks.jpg>
    It looks like there will be a lot of work involved in just removing
    the old one and replacing it with a new one because of all the
    electrical connections that go through it as it appears to be one
    piece of plastic.
    The two holes that you can see should have the two pieces of plastic
    which are above the clocks in them but when they hit the road with its
    previous owner it must have been so hard that it broke all three which
    he bodged back on then gave up and decided to flog the whole thing on
    ebay. The third mounting point is still attached (to the left of the
    bit the wires go in to on the top right) and has been melted back into
    position but you can see it's lacking support.
    BGN, Feb 4, 2006
  19. BGN
    Christofire Guest
    Exactly. If people didn't want to help, they wouldn't. I wish I
    could've done more for the KRC lot as I got a fair bit of enjoyment
    following the saga, but as I knew about cakes they got cakes.
    Sure, if I'd known about How To Perfectly Set Up Any Race Bike Ever it
    might have helped more, but unfortunately for them I went for cakes.
    Christofire, Feb 4, 2006
  20. BGN
    Cab Guest
    Stop whinging you soft bugger. Anyone on the NG that helps you, does so
    'cos they want to.
    Cab, Feb 4, 2006
