Er5 - Phase the Second.
Discussion in 'UK Motorcycles' started by David Alderton, Jun 2, 2006.
  1. Previously, I was having problems getting my ER5 to work at all. It
    wouldn't start on the button, despite it being on the optimate, and
    so on.
    It turns out that it was the little circuit that sends the power to
    the battery was chucking out 19V, rather than the 14V it was meant to
    top out at. So a trip to see the man (one new circuit board, chain
    and sprockets battery later, and it was all running fine again. The
    old battery was a sealed one, and had actually swollen inside, which
    might have been a result of the wrong volts, so it's probably good
    that it stopped working).
    So thanks for the help and advice then...
    As 6 weeks is obviously far too long a time to have a fully
    functioning motorcycle, the speedo stopped working today on the way
    in. So, it's out with the Haynes manual tonight and over the weekend
    and try to see if I can fix it, or I'll take it back to the man and
    get him to do it, and change the back tyre at the same time.
    Stupid question (#76 in a series): Do you need to change both tyres
    at the same time, or have I got this idea into my head from
    somewhere?
    Also, how much is it going to cost, so I can get an idea if I'm being
    ripped off or not?
  2. Most certainly not. If your'e happy with the tyres you have, you can
    replace the worn one with one of the same, but you can always mix and
    match a bit. Roughly, you'll get twice the mileage out of the front as
    you do the rear, so why throw money away?
    Grimly Curmudgeon, Jun 2, 2006
  3. I shall replace like with like, in that case then. Thank you very much.
  4. David Alderton
    BGN Guest
    The speedo cable on the ER-5 is prone to snapping or coming undone.
    Look at the back of your speedo, you will see one thick black cable
    coming out of the back of it near the edge. This is the speedo cable.
    Make sure it's in snugly, follow the cable down to your front wheel
    and make sure it's connected there.
    If it's connected and tight both ends unscrew it from the back of the
    speedo and you will see that a bit sticks out that turns around (which
    makes the speedo work and the mileage increase) when the front wheel
    rotates. If you stick the bike on the centre stand and get someone to
    push down on the back (which lifts the front tyre off the floor) you
    should now be able to rotate the front wheel. As the wheel rotates
    faster you should see the 'sticky outy bit' of the cable rotating. If
    this doesn't rotate then you're likely to have a snapped speedo cable.
    This is not expensive to replace and even I can do it so it must be
    easy.
    BGN, Jun 2, 2006
  5. I have done this, and both ends were connected.
    I did the top bit, then pulled the rest of the cable out, it appears to
    be snapped. So I'm off down the shops tomorow.
    Thanks,
    Dave.
    www.dave.alderton.org
    david.alderton, Jun 3, 2006
