ER5 maintainance
Discussion in 'UK Motorcycles' started by David Alderton, Feb 20, 2006.
  1. Hello there.
    Just got a couple of questions about keeping my ER5 on the road, as it
    seems to be having a few problems at the moment and am looking for some
    help.
    1) It seems I have to adjust the chain every 300 miles, is this normal?
    My riding involves commuting down 15 miles of bumpy B-roads a day and
    occasional longer trips down dual carriageways.
    2) The battery needs recharging every few days. I keep the bike in
    garage (unheated) so I've a feeling that the cold weather might have
    something to do with it.
    I took the bike from Bicester to Leeds on Saturday, I'd left the
    optimate charging it overnight, and the light was green when I set off.
    On Sunday, on the return trip, bike started on the button, despite
    being left outside and uncovered overnight. This morning, the battery
    was playing up again, but 10 minutes on the charger got it going again.
    Any ideas? Or shall I nip to the new battery shop on my way home?
    TIA,
    David.
  2. David Alderton
    David Alderton emerged from their own little world to say
    Paging BGN. Someone needs your expertise.
    wessie, Feb 20, 2006
  3. David Alderton wrote
    BGN is your man.
    Not if you oil it and adjust it right and ride anywhere at anything
    approaching near sensibly. Odds on you are adjusting it a bit too
    tight/often.
    That is wrong. A battery should get well recharged in a 15 mile ride.
    Either something, lights perhaps, is being left on when you park or the
    battery/charging system is stuffed.
    Check it with a meter of some description first because it may not be
    the battery and with the price of motorcycle spares and the profits
    arising therefrom approaching those of the drug companies you don't want
    to be spending money on quack cures do you?
    steve auvache, Feb 20, 2006
  4. I oil it regularly, maybe not regularly enough though. There's not a
    lot of sudden, hard accelerating either.
    I'll re-read the book when I get home, just to be certain I've got
    the tension correct.
    I fear it's the latter. Since it's been happening, I've been making
    double extra sure that the lights are off when I park it up. And 3
    hours down the motorway yesterday should have made sure that it was
    OK.
    I shall go in search of such a meter and have a look.
    Much appreciated.
  5. David Alderton wrote
    If you oil you chain regularly it is unlikely in the extreme that you
    are under doing it. Unless you use something like a Scotoiler you will
    almost certainly be applying far more than enough but nobody has ever
    suggested that too much oil is bad for the chain so don't worry about
    it.
    It may be the chain is going home in a way that is entirely acceptable
    for the mileage it has done and treatment it has received getting there.
    What chain is it and how far has it travelled?
    Report back.
  6. David Alderton
    R obbo Guest
    You sod!
    Fancy letting the ER5 wrecker near the poor mans machine.
    That's not sporting is it!
    R obbo, Feb 20, 2006
  7. I bought the bike second hand and it had 8900 miles on the clock. It
    stood in a garage for 6 months, until I had passed my test and was
    able to pick it up, then it passed the MOT etc, and was back on the
    road. Since late december, I've done 2000 miles on it, a mixture of
    commuting and motorway/dual carriageway miles. If it is the original
    chain (which I highly suspect it is) then maybe it is going home. I
    will confirm details a bit later on, when I've the service history to
    hand.
    This will be done. I suspect I will be looking for the volts and amps
    readings.
  8. Well, last night, it wouldn't start (again). The starter motor was
    turning over but the engine wouldn't start. I left it overnight, and gt
    the bus home, and in again this morning.
    I just retried it, and the engine went 'Ba bom' once, and then nothing.
    Starter motor is just turning over, and sounding ill. I'm going to call
    the AA. They might have an 'it's fucked' diagnostic tool and maybe get
    it started, so I can at least get it back home and play with voltmeters
    and suchlike.
    David Alderton, Feb 21, 2006
  9. David Alderton
    Whereabouts are you located?
    platypus, Feb 21, 2006
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    In the garage, sobbing, would be my guess.
    Wicked Uncle Nigel - To stay young requires unceasing cultivation of
    the ability to unlearn old falsehoods.
    Wicked Uncle Nigel, Feb 21, 2006
  11. David Alderton
    Whilst looking at a bike-shaped space.
    Pip, Feb 22, 2006
  12. Bike is in Oxford, but it should be in Bicester. I'm trying to find
    Auntie Carole's breakdown number.
    David Alderton, Feb 22, 2006
  13. This wasn't too far from the truth.
  14. Thanks a lot, help is on the way.
    Much obliged.
    David.
  15. David Alderton
    Shit! She's had a breakdown? Must be all the stress of looking after
    all her nephews and nieces ;-)
    Seriously - I carry the card with all the CN numbers on, in my wallet
    at all times. Never know when it will come in handy.
    Pip, Feb 22, 2006
  16. David Alderton
    BT,DT,GTFTS
    Pip, Feb 22, 2006
  17. David Alderton
    BGN Guest
    You may have the chain too tight. My chain gets adjusted every five
    thousand miles or so. The last chain lasted over 20,000 miles. Every
    week after a ride (or after about 300 miles, whichever comes sooner) I
    lube the chain. I give the bike a good wash as normal, take it out
    for twenty minutes and get the tyres pumped up and then lube the chain
    when I get home while it's warm and then leave it alone until I need
    to use it again.
    Chain lube isn't expensive and tkaes about a minute to apply.
    How often do you ride it? Mine is always okay and it sometimes only
    does two four mile trips to/from work a day.
    How old is it?
    My ER-5 has had the same battery from new (four years) and it's never
    let me down. I've just left the bike outside for a week while I was
    travelling for work and it started on the press of a button. It's
    never had a 'recharge' and doesn't have an optimate - it works without
    having anything like that - perhaps I've just been fortunate.
    BGN, Feb 24, 2006
  18. David Alderton
    BGN emerged from their own little world to say
    Turning it upside down every couple of months helps.
    wessie, Feb 24, 2006
  19. I think I have been running it too tight, so thanks. I'll keep that
    advice in mind.
    During the week, 30 miles a day. I ordered a new battery and it
    arrived today. Catching the bus to work, with my shiny new battery, I
    was overjoyed at the prospect of not having to use public transport
    again for a while.
    I've just unwrapped it with a view to the quick 5 minute job of
    removing the old one, and installing the new one. Turns out, I need
    to add the electrolyte and charge it for 5 hours before it will work.
    I could cry.
    Y Plate.
    Thanks again for your help.
    David Alderton.
    David Alderton, Feb 27, 2006
