Hello luvvies. At prawn's 25th anniversary event I questioned Mr. W Courier about a white goo that I could see through the engine oil sight glass. I recognised the goo from my old Rover 214Si that used to spew water into its oil. Mr. Courier confirmed that it looked very much like water was in it, but upon sticking a twig into the engine the oil looked fine. The coolant was at its normal maximum level (it would appear never to have lost a drop of water since I came to own the machine 12,000 miles ago) so I had no idea where the contamination might have come from. Today I did the usual weekly checks on the bike (ie. Is the bike still sitting outside the house, how many wheels does it have) and I noticed the coolant level had dropped from its normal Maximum to just below Minimum. It sounds like it may well have a leaky gasket. As I'll be getting a Man in to sort this out, do you know how much I'm likely to have to shell out to have this fixed? It's payday tomorrow. :( I suppose it'll need a new (head?) gasket, new oil, oil filter and probably worth changing the coolant itself? Plus an hour or two labour?
