Whoa... this is going to be a classic. If you have not caught the coverage on WSB at Assen, you're missing out. The revised Assen circuit met with skeptical response, but the shorter track can still deliver great races as was proven yesterday. After claiming leg 1 with confidence and solid performance, James Toseland was prominent in leg 2 as well. Together with Troy Bayliss he was duking it out on the last few laps, as Max Biaggi had to drop off and finish third. The maneuvers in the last lap were so spectacular, it almost looked choreographed. In fact, the moves were identical in all three last laps, where Toseland was trying to overtake Bayliss. In all three laps he was successful initially, but swift counter moves by Bayliss meant that James was trailing on the finish line again. However, on the last lap, James *did* make it stick. Exiting Geert Timmer with a lead, storming to the finish. But Bayliss had slightly better traction. Toseland, on the dirt, was threatened to be overtaken at the finishline, so he pushed it just a little more..... Toseland's front wheel lifted a few inches above ground... Bayliss kept his front wheel down, and on the finish line.... a 9 millisecond win by Bayliss. Wow... I don't think racing can get much better than this. Troy, the reigning champion no less, was moved to tears. James really gutted. However, James does look set to take Troy's crown at the end of the season with his rock solid performance so far. Bram
