Engineery types: Epoxy?
Discussion in 'UK Motorcycles' started by Catman, Jan 7, 2007.
  1. Catman
    Catman Guest
    I am in the process of molishing my pillion seat to take a Givi top box.
    Having removed the foam, the plastic 'frame' is actually dished. For
    a variety of plastic related reasons, I need to raise the mounting plate
    about 15-20mm above the level of the frame (to allow the rear of the box
    to clear the rear plastic of the bike).
    I can used some mdf or similar for that bit, but the bolts from the
    mounting plate actually have to go through a section of the dished part
    of the frame, so there is some 10mm between the plate and the frame.
    Not ideal I think although it does seem pretty strong.
    To make it a better mount, it seems that I could fill the 'dish' with
    something like epoxy to create a flat, solid base for the plate and
    'spacers'
    Thing is I need about a litre of the stuff. From B+Q that is gonna cost
    So suggestions for suppliers, or alternatives? Maybe Isopon or similar
    would do as well?
    TIA
    www.cuore-sportivo.co.uk
    Catman, Jan 7, 2007
  2. Catman
    I wouldn't use any kind of automotive filler, they're likely to crack
    if you drill a hole through them and bolt something through them.
    Timo Geusch, Jan 7, 2007
  3. Catman
    Catman Guest
    Noted, ta.
    Catman, Jan 7, 2007
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Catman
    It's also going to get pretty hot whilst it's curing, if you try to do
    it all in one go.
    I'm not sure I have any better suggestions, TBH. If you do decide to go
    this route, have a chat with your local friendly model shop, they stock
    pouring epoxy in reasonable quantities.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Wicked Uncle Nigel, Jan 7, 2007
  5. Catman
    Catman Guest
    That had occurred as well. Layers would probably be a better idea.
    Yep, that was one of my thoughts.
    Cheers
    Catman, Jan 7, 2007
  6. Catman
    Catman says...
    Fill it with expanding builder's foam, shape it so the top is flat and
    then a skim of fibreglass over the top to hold everything together and
    make it paintable.
    Lozzo, Jan 7, 2007
  7. Catman
    Pete Fisher Guest
    A Nordwest owner who made his own custom twin headlamp nose fairing
    reckoned Holts Bumper Repair was v. good for drilling and shaping after
    curing. I have found it useful myself to repair a seat mount on the GFR.
    TBF that involved 'gluing' a pre-drilled plastic bobbin in to place
    though. Also v. expensive.
    | Pete Fisher at Home: |
    Pete Fisher, Jan 7, 2007
  8. Catman
    Eiron Guest
    Epoxy seems to be £20 or so per litre. Plenty of chandlers have it
    or mail order suppliers such as http://www.cfsnet.co.uk .
    You need some filler and glass mat to reduce weight and increase
    strength, or think of a different solution.
    Eiron, Jan 7, 2007
  9. Catman
    Catman Guest
    I had considered the foam, but the fibreglass had escaped me. I like
    that idea, been a long time since I did any 'laying up'...
    Nice one.
    Catman, Jan 7, 2007
  10. Catman
    Catman Guest
    Hmm. Define V. expensive for me?
    Catman, Jan 7, 2007
  11. Catman
    Catman Guest
    How about foam filler with a layer of epoxy over the top?
    Catman, Jan 7, 2007
  12. Catman
    Catman says...
    Looking over the other replies, I'd bolt some pre-drilled bobbins in
    place before filling with the foam to give something solid for the box
    to bolt through that won't deform.
    Lozzo, Jan 7, 2007
  13. Cheapest option would be cement. Seriously. If you mix in fibreglass
    strands it'll be strong and cost next to nothing.
    Polyfilla would do, too.
    If you really want to go lightweight, do the Loz thing.
    Grimly Curmudgeon, Jan 7, 2007
  14. Catman
    Catman Guest
    I think that may well be the best option. I've just measured the void.
    It's actually less than 0.75l so I shall consider my options.
    Catman, Jan 7, 2007
  15. Catman
    Beav Guest
    Or you could use a fibre filled filler wot's full of glass figres. Works
    just like normal body filler, but it won't crack and split when you drill
    it. Price is around a tenner for a gallon can from your friendly
    neighbourhood car body supplier. (Brown Bro's, Supertune, whoever)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 7, 2007
  16. Catman
    Catman Guest
    Nice idea. Thanks.
    Catman, Jan 7, 2007
  17. Catman
    Beav Guest
    Then you can scoop the mess out with a trowel. Fibregalss resin will eat the
    foam for fun. You need Polyester resin.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 7, 2007
  18. Catman
    Beav Guest
    That'd work perfectly and the foam will hold any bobbins you care to use
    too.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 7, 2007
  19. Catman
    Catman Guest
    Something like:
    U-POL SMC?
    I'd give a ling but www.bodyshopwarehouse.co.uk dunt work like that that
    the search appears to be FUBAR
    It's SMCB-2
    Catman, Jan 7, 2007
  20. Catman
    Catman Guest
    Epoxy easts polyurethane?
    Catman, Jan 7, 2007
