In the continuing saga of trying to use the pair of 16.5" Dymags that I have on the Team UKRM racer, I've run into a problem with the front discs. The hub dimensions are identical to those for the 17" wheels, meaning the standard discs (or EBC or other replacements) would bolt straight on. Except that the hub is drilled and tapped for 6 holes instead of 5. I've a number of spare EBC disc carriers (to which the rotors attach, using floating 'buttons'). Would it be feasible to fill the holes in a carrier with weld and re-drill for 5 holes? Can anyone think of any other potential solutions?
